Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony kf60we610 brightness problems
I have a 60" Sony kf60we610. The picture was very dark and I had to have the brightness level turned all the way up. I just replaced the bulb and it still is not bright...have the brightness level at 100% even at night!
  • 1 more comment
  • james12345 Jan 08, 2008
    I have the same problem. can anyone help?
  • aheermance Oct 19, 2008
    I have the same problem since the day we bought it. The picture was awesome in the store. After it was delivered to our home it was like a different tv. It's so dark you can barely see and the color is so dull. Don't know if we should spend the money on a bulb or not
  • tomsunclub Nov 04, 2008
    I have a dull picture and brightness is all the way up should i replace bulb r look elswhere?
    Genius:
  • 1,139 Answers
The problem might be with the circuitry driving the LCD screen. Since the back lighting blub has been changed the only thing that could cause this issue would be the screen brightness which is controlled by the LCD circuitry. You will need the schematic to aid you in the measuring of these voltage values.
Posted on Nov 15, 2007
Sony Grand WEGA KF60WE610 - Over the past 6 months, bright points of light have developed on the screen which are always there, but are noticeable when the the background is dark.. Is there anything I can...
If they look white or like pixels out this model is prone to a bad optical light engine---it is the heart of the set and most expensive part as well--typically it starts with one or two and over time more "appear".
Dec 06, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Brightness problems with sony kf-50we610
This is typical for a set that uses a lamp, as the lamp needs to warm up.
If it is taking longer than normal to brighten up, then your lamp could just be aging and needs replaced.
Jun 19, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
NEED MANUEL Sony Grand WEGA KF60WE610 60 in
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KF60WE610
Oct 18, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
My Sony Wega KDF-60XS966 is dark You can see the picture and the brightness is turned all the way up but it still looks dark Do I need a bulb?
Yes, its time to replace lamp in tv.
Lamp replacement is easy and procedure would be written in user manual.
Thanks.
Jun 10, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a sony kf-60we610 2004 and the bulb is good, but the tv doesn't stay as bright as it use to and I have the brightness max out. any ideas?
IF the lamp has been in the set for a while it may be your problem---some of these sets before the lamp fails the picture will get darker--lamp will look ok but can cause this trouble.
If you replaced it at some time with a "Generic" replacement other than an Original Sony--that can also be the trouble.
Lamp life is about 2,000 hours and time can pass quickly.
Let me know if I can help--I am here to help.
if this information helped you rate this solution as I do this here for free.
SD TECH
6bc0523.jpgSony XL2100U lamp.
Dec 26, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Turned on tv and got a green tinted picture. sometimes can be cured by turning tv off and then back on. if i leave tv on the problem comes and goes . this is a sony kf60we610
Take out all the connections,to the main video backlight board.Check for lose connections,damage connections cables?Reconnect all connections,turn on the tv jiggles the cables connections,see any tint,or flashes,than ur cables wiring must change have internal cables damges,not than ur backlight video board degrading,just not have serious prob.yet.
Nov 04, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
I have a Sony Grand WEGA KF60WE610 and i get green lines or dark lines running across the screen, they are horizontal lines. I have had the bulb replaced and it hasnt changed. Any ideas?
It sounds like you possibly have a bad optics block. If thats the case it is not a user replaceable part due to the tear down to get to it. Is there anyway you can email me a picture of the television with the symptom and I can possibly help from there? My email address is tvtek(at)msn.com
Oct 30, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
508 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
