User manual on how to set up a recording Model # HR-VP58U S.# 174 Q1941
SOURCE: Instruction Manual JVC HR-J425
You need the remote working to get at the on-screen setup menus. make sure the remote is set for the VCR (VCR button) and try the menu button. Are you sure this is the right remote for the VCR. May have to get a new remote. Make sure it is a universal that has a MENU button.
SOURCE: Operators Manual
unfortunately there are no manuals available for your model.They have been discontinued.You will have to contact the jvc Customer Care Center at (800) 252-5722 and ask them to email you a copy of it.
Or you can also send them an email by clicking on the below link and submitting the form:
https://support.jvc.com/consumer/support/support.jsp?pageID=5
SOURCE: Lost manual. Cannot get
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
