Question about HP Officejet 9110 All-In-One InkJet Printer
Stripes in my color print jobs with Officejet 9110
When I attempt to print color objects, stripes appear. I changes out all my ink carts and still, I have stripes. I have not replaced the heads yet, but I have cleaned them. Please help.
Re: Stripes in my color print jobs with Officejet 9110 - HP Officejet 9110 All-In-One InkJet Printer Printers & Copiers
How do you access these print utilities?
Posted on Jan 03, 2008
  • 85 Answers
HP software comes with a head cleaning option.. run that thru 3x and make sure you clean all of the printer ink cartridge using rubbing alcohol.
Posted on Nov 13, 2007
0 characters
3 Points
Prints B&W in Horizontal Stripes
I received an answer elsewhere. Thank you.
Jan 26, 2010 | Canon Printers & Copiers
Blue color appears pinkinsh/now stripes and smudging
Are you using third party ink? make sure your ink is xerox OEM. This will clogg up the inkjets and ruin the print head for ever, If you have always used the third party ink then you might want to get a new print head. . If you have used xerox ink then It sounds like the magenta reservoir has spilled over the cyan. This is caused by moving the printer and not waiting for the cool down procedure. Also you might want to change the print head wiper. If the print head wiper is over used it won't clean the print head properly and what that causes is for ink to build up and causes smudge. also make sure the drum maintance kit is still in good shape. (its the yellow roller on the right side of the printer. Well hopefully this helps .
Nov 20, 2009 | Xerox Phaser 8400 Laser Printer
Pictures are printed with stripes and poor color
make sure your printer printed an initialisation or alignment sheet once you installed the new cartridge.
you can try a partial reset of the printer and check if the printer prints fine,also there is an option of cartridge calibration in the printer properties or the printer software installed in your computer
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Take some paper towels, fold them in half, spray them with alcohol FREE glass cleaner and set your color cartrige on the paper towels and let them soak for thirty minutes or so. DO NOT USE ALCOHOL it sets the ink. also clean the thin plastic strip in the back of the print heads this is the encoder strip and it tells the print heads when to dispense if this is dirty from overspray it will affect your print quality. Use q tips and the same alcohol free window cleaner.
Jun 04, 2009 | HP Officejet 9110 All-In-One InkJet...
Hp 9130 printing blue stripes on photos...
On the control panel, press MENU.
Press (up) or (down) to move to the item you want, and then press (select).
Go to maintainance.
Press - or + to select the value that you want, and then press (select) to save the setting.
If there is no - or + around the setting, the setting cannot be changed.
on the maintainance tab is,
clean heads, align, calibrate, etc..
Hope this helps
Apr 16, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Magenta is not printed
I think the cart is defective ,,If its within oneyear try getting it replaced >....
Mar 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
Cannot print in color on HP OfficeJet 9110 All-in-One
Nothing to do with the driver, I'd say the cartridges are your problem, skipping lines and missing colour are indications of needing new ink carts, are carts new HP ones?
Jan 19, 2008 | HP Officejet 9110 All-In-One InkJet...
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
You could try doing an alignment which i think is a maintenance option on this machine. You should find it in the driver options. You could also look at my previous posts about under head cleaning. Look here ->
Sep 18, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 9110 All-In-One InkJet Printer Logo
293 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
