Cars & Trucks Logo
j
john bader Posted on Mar 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1980 colent resavor
Coient resavor?
vtec
Level 3:
Master:
  • Cars & Trucks Master 371 Answers
  • Posted on Mar 02, 2015
vtec
Level 3:
Master:
Answers
371
Questions
Helped
85335
Points
1111
Coolant reservoir ? probably close to the radiator ?
2answers
1980 colant resavor
wht about it... need one or whatitis....
What coolant to use for 1996 e230 mb elegance
any will do just use universal somer and winter colent
2answers
My 1981 ford f100 brake light comes on when I come to a stop but goes off when I start accelerating?
check the brake fluid level, there is a float in the resavor when you stop all the fluid moves to the frount of the resavor causing the float to drop and turn on the light. fill the master cylinder with DOT 3 brake fluid.
2helpful
2answers
How to change the power steering fluid on a 2003 carvan
remove the power stering return line and place the loose end in a bucket and start the engine then keep adding power stering fluid to the resavore intill clean fluid runs from the return line the reinstall the return line and top off the resavore
Where is thermostat located ?
look for two main colent hoses near the top of engine,you dont tell me what car you are talking about??????.adrian,,,,,
I have a 1990 Buick Regal v-8 Does the radiator fluid move from radiator to reservor as engine heat and cools or remain in radiator except under extreme heat conditions?
A certain amount will run into resavor or draw out after it is shut off no matter what the tempature is, the only exception is if it is low on coolant in the radiator it will draw out of the resavor to maintain the right amount to the cooling system. but when engine is running it should not do either one because the coolant is flowing.
Colent is full still clicks on and off?
Coolant is not what the a/c works on. It works on refrigerant which you cannot check the level on you must attach gauges and check the pressures
Installed new power steering pump on 2003 Hyundai Elantra still noise. How do you bleed the system?
Best way i found is to make sure the resavor is full, and start car and turn wheel back and forth lock to lock untill all the air is out of the system or when the noise goes away. Now if there isent a bleeder hole on resavor cap you may have to leave it loose so the air has a place to excape. Be patent it might take a while.
Brake problem toyota carina e "94
sounds like break hose is not letting fluid run back to resavor. have you done a break job lately and maybe kinked a line. break lines ar two way, fluid to caliber and returns to resavor thru same line. you also might have a caliber sticking.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
