Question about Minolta magicolor 2400W Laser Printer
White band on photo glossy output
There is a white band from the top to the bottom about 3/4 of the way across the page on my photo glossy output.
I have printed sucessfully on this same paper many times. I have printed about 80 some pages without any issues.
There seems to be adequate toner in all cartridges.
  • bic2 Feb 17, 2008
    I printed about 60 pages of print and the printer seemed to get quite warm. Towards the end of the job pages stuck together. Now, after that job, I get white streaks down the left side of each page. I tried to clean the laser with kleenex; didn't make any difference...that is IF I actually found the laser heads. The instructions were not exactly clear.
  • Dave576 Feb 21, 2008
    I have the same problem regarding a white line running through the print area!!!
    Can anybody help???
    Problem Solver:
  • 5 Answers
Open printer, remove drum, clean laser lens with soft dry cloth, reinstall drum.
Manufacturer's Instructions
website: printer.konicaminolta.com
white vertical line (s) / how to clean the laser lens
Cleaning the printer. (5 pages)
Worked for me
Watemusic
Posted on May 04, 2008
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Lighter bands across copy using Canon F 132500 copier
Open the flap to expose copy platen and press print you should get a flat even black
if you get the white bands do the following:
Clean the corona wires open the cover pull out the sliding charge wires and clean with q tio and acoho or a pencil erasure
If that does not work remove top glass and clean mirror and bottom of glass
Dec 24, 2008 | Office Equipment & Supplies
Black smugs on any glossy print
check the fusing area. (where the paper is heated)there is an adjustment for envelop . set it to normal because the pressure on fixing unit is too loose.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
May 13, 2007 | Konica Minolta magicolor 2300DL Laser...
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Minolta magicolor 2400W Laser Printer Logo
173 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
