Question about HP OfficeJet D135 All-In-One InkJet Printer
Scanner Failure My printer works fine one time and then I have to turn it off then back on to print something else. Any ideas? Also, the light in side that goes across during printing/copying is always on. Is it supposed to be? Or is that the problem?
Test your power supply for proper output.
Posted on Nov 18, 2007
My hp printer 6110 officejet all in one keep giving message scanner failure when i want to print something
Please make sure that the printer is connected to a wall outlet and not to a surge protector because surge protector distributes the total electric supply equally to each and every device connected to that surge protector. Printer might work and might not with a surge protector but it will always work fine with a wall outlet till the hardware of the printer and power chord, adapter are working fine.
some times scanner failure error comes if it is not getting enough power supply.So if it is connected to a surge protector then I will suggest you to disconnect it and connect it directly to a wall outlet.
Now scan or copy any document and see if something happens.
If not the do check while you press scan or copy button the scanner light is moving or not?
If scanner light is not moving then do a hard re-set.
Hard Re-Set :
- disconnect power chord from the back of the printer and then from wall outlet or surge protector.
- wait for 40 secondsand then connect the power adapter to wall outlet and then to the back of the printer. The try to scan or copy....still not working then check if the scanner bulb is glowing or not?
If scanner bulb is not glowing and if you dont hear any noise while you press scan or copy...then printer hardware has gone bad and you need to replace the printer
Feb 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP office jet 6110 all-in-one Scanner Failure message cannot be erased. When power is switched off/on makes load grating noise and Scanner Failure message reappears. Copier function will not work either.
Print head sticking needs oil on shaft that its slides on. Open cover and put a drop of oil on each side print head Shaft cut it back on and see if this helps .may half to do this 2 or 3 times to get the oil on to bearings . They dry out over time. Good luck
Aug 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 2600n printer printing light on the left side of the page
clean the scanner & calibrate the printer thre times ur problem will be resolved
Jun 03, 2010 | HP Color LaserJet 2600n Printer
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Light print problem
excellent idea! we have a samsung scx 4100, when scanning produces light print on one side of the page (left side). How does the scanner removed. to get to the scanner.
Mar 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Officejet 7310: Scanner Failure
If you get a "Scanner failure" message then the problem is the motor itself. Notice how the motor works fine when the scanner is moving slowly, like copies or faxing with the original laid on the glass. HOWEVER, the scanner failure comes up when you use the automatic document feeder on top. Why? Because the scanner assembly has to move to the other side of the printer at high speed to get into position, and it's the high speed movement that triggers the error on the printer. The motor is expensive, part number Q3450-60003. Many other models use the same motor, maybe you could find one cheap somewhere and swap the motor?
Jan 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure
Sorry, no solution but just to inform you that I have the same problem since last weekend. Cleaned the scanner head but no result. Any other ideas?
Oct 06, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP PSC 1410 will not print, printer icon is no longer on the bottom right hand corner of screen either. When i turn off the printer and turn it back on it prints the test page only.
Dear kappa, It is the problem related "Alignment of cartridge" your printer is working properly, I am suggesting a method, with the help of this method you will never get test page until you lift out your cartridge from your printer. When next time printer print a test page, take it and put it into the scanner, remember the printing area should be the side of mirror and the printer prints on the above side of the paper should be left side of the scanner. And press scan button, you will see the green light will be blink and a voice of scanner you will hear. After 30 seconds light will stop blinking, Next time when you will turn on your printer, it will not print test page.
Sep 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
