Sometimes it will help when you press the display button a few times. No display is one of the possibilities. But when the cable or the screen are defect, even pressing the button a thousand times won't help.
Success
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
I have a sony cybershot DSC-S650, the LCD was very dark and could not
see anything except if I pointed it at a bright object, everything else
worked ok. I could take pictures but could barely see them in playback
as well.
I took it to Sony authorised repair outlet and was told
the CCD was damaged, they charged me USD $55 to repair it (in Quito,
Ecuador)
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
The camera will still work fine. The screen is only for framing your pictures and reviewing them. It will be hard to take pictures that way. Just get a new camera. It will be cheaper than repairing the screen.
