Question about Frigidaire GLTF1670A Front Load Washer
Frididair GLTF1670AS Front loader washer problem-water will not run in
Water will not run into the washer initially, but it will run in during the rinse cycle
  • jenbiam Nov 16, 2007
    Same thing....washer won't start from the normal posotion, but will start if it is set further ahead in the cycle???
  • Anonymous Dec 08, 2008
    I turn on the washing machine, and the water runs for 2 seconds and then stops. The timer keeps decrementing to 1 and stays there. Not sure why the water pump on the washing machine shuts off the water after only 2 seconds.
  • 249 Answers
IT could be the water heater element it would prevent it from moving to next cycle . Close Ireland bye bye
Posted on Nov 21, 2007
Water does not drain
Is the drain line clear? Also sounds like time on water inlet is running to long. Front loaders don't use that much water.
Mar 21, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
My front loader LG washer works fine during the load, but when I come a while after the load is done, water has seeped back into the washer and I have run the drain cycle to get it out. LG says it needs...
If you have the capability its probably a leaking seal on the water input line at thetop of the water. Often its a simple hoseclamp that needs tightening. Without looking myself thats the easiest solution. Hope this helps!
May 09, 2011 | LG WM-2277HW Front Load Washer
Is there any way to adjust my front loader Samsung to have more water during the wash cycle? I was washing one light blanket and during the wash cycle I had to add a dish towel, when I put my hand into...
Remember this washer is a water saver.I have the same question on my new washer.What i do is increase the size of the load.
Instead of running it on light load, ill put it on heavy this will allow more water to fill.
May 04, 2011 | Samsung WF203ANW Front Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I don't really have a problem, except that my water bill is eating me alive. Approximately how much water does a full load in my 26912 with one rinse use? And how much water are newer models using on...
Most standard top loading washers have a 35 gallon tub capacity. If you go with a High Efficiency (HE) model washer, which can include the Oasis and Cabrio TOP LOADERS, and the Duet, Elite and Epic FRONT LOADERS, they use about 5 to 7 gallons. High Efficiency washers also do not have a continuous motor in action during agitation or tumble cycles, while most standard top loader have a drive motor that runs throughout the cycle. this can also cut down on the amount of electricity that is used. I hope this helps you.
Feb 17, 2010 | Washing Machines
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
Can't see water level at all
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
Nov 02, 2017 | GE WBVH6240F Front Load Washer
Are you supposed to see the water level?
they dont take alot of water..thats one of the good things about the new machines like that. they use only what they need to do the laundry and thats it.thats why they call them so efficient
Jan 21, 2009 | GE WBVH6240F Front Load Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire GLTF1670A Front Load Washer Logo
217 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
