Sub-Zero 611 / O Bottom Freezer Refrigerator
Problem for Sub-Zero 611 / O Bottom Freezer Refrigerator
My refrigerater temp won't go below 55 degrees. Is
By llshipp on Jul 08, 2009
My refrigerater temp won't go below 55 degrees. Is there something to try befroe bringing the repair man out? The freezer seems to work fine.
Best Solution
posted on Jul 09, 2009
Helpful)
mclaup
Rank: Master
Rating: 86%, 16 votes
The air door "cold control" may be obstructed or the air return may be obstructed. The air return takes the air from the refrigerator section and delivers it to the coil. It must be clear for the fridge to operate properly. The cold control is just a door flap that opens and closes and allows cold air to enter that part of the cabinet. Open the cold control more and see if that helps. You should feel more cold air coming from it. If you don't then there's an obstruction.
If you have a thermometer that goes below zero, place it in the freezer. It should read 0 to -5 degrees f. If it doesn't then there may be another problem.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sub-Zero 611 / O Bottom
Questions and Unsolved Problems for Sub-Zero 611 / O Bottom
Do you recommend Sub-Zero 611 / O Bottom Freezer Refrigerator?
Answer
Answer
I hear the fan is on all the time in my Subzero unit. Is this normal?
Answer
Sub-Zero 611: The control panel and light in the refrigerator are not working. The compressor is... (More)
Answer
part that controls the medal arm that drops down to make ice and retacks to stop on model 611
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 611 / O Bottom...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
