1994 Buick LeSabre Logo
A
Anonymous Posted on Mar 01, 2015
Wire plugs to coil.1994buicklasabre - 1994 Buick LeSabre
Claude Kayser
Level 3:
Top Expert:
  • Buick Master 9,098 Answers
  • Posted on Jul 23, 2015
Claude Kayser
Buick Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066992
Points
28436
Wiring Diagrams - AutoZone
www.autozone.com/repairinfo/.../repairGuideContent.jsp?page...
AutoZone5: 1986-88 Buick Lesabre Wiring Schematic. Click image to see an enlarged view ....46: 1997-98 Buick Chassis Schematic. Click image to see an enlarged view.
1helpful
2answers
How do I replace the ignition coil in my 2002 ford taurus
Removal & Installation
3.0L (VIN S) Engine
  1. Disconnect the negative battery cable.
  2. Unplug the engine control sensor wiring connectors from the ignition coil and the radio ignition interference capacitor.
  3. Tag and disconnect the spark plug wires from the coil by squeezing the locking tabs, then twist the tab and pull upwards.
  4. Unfasten the four ignition coil retainers and remove the coil and the coil ground wire the radio ignition interference capacitor. Save the capacitor and coil ground wire for re-installation of the coil assembly.
  5. Wipe the coil towers with a clean cloth dampened with soap and water. Remove any soap film and dry with compressed air. Inspect the coil for cracks, carbon tracking, dirt or damage and replace as necessary.
    Fig. Ignition coil assembly mounting-3.0L DOHC engines
To install:
  1. Place the coil, capacitor and the coil ground wire onto its mounting location on the right hand valve cover.
  2. Install the coil assembly retainers and tighten to 45-61 inch lbs. (5-7 Nm)..
  3. Apply dielectric compound D7AZ-19A331-A or its equivalent to the spark plug wire boots.
  4. Attach the spark plug wires to their proper terminals on the coil and make sure the boots are firmly seated so that the locking tabs engage.
  5. Attach the engine control wiring connectors to the ignition coil and the radio ignition interference capacitor.
  6. Connect the negative battery cable, start the vehicle and check for proper operation.
There is a misfire in my engine, changed plugs & wires. now it reads that the fuel leveling sensor is bad, will this help?
If there is a misfire, the cylinder that it is misfiring in will be recorded as a code in the computer.
Have the car scanned to determine which cylinder is bad. Then, replace the coil pack going to that cylinder.
Ignition Coil Pack Removal & Installation 2V Engine To Remove:
  1. Twist the spark plug wires off of the ignition coil towers. Mark the spark plug wire positions so they can be installed in their original positions.
  2. Disconnect the electrical connector from the ignition coil. CAUTION
    When removing the spark plug wires, a slight twisting motion will break the seal and ease removal.
  3. Remove the mounting screws and remove the ignition coil.
To Install:
  1. Position the ignition coil pack on engine.
  3. Connect ignition coil pack electrical connector.
  4. Match previously marked spark plug wires to ignition coil and install.
4V Engine To Remove:
  2. Remove the screws and the water shield
  3. Mark spark plug wire positions
  4. Disconnect the spark plug wires from the ignition coil CAUTION
    When removing the spark plug wires a slight twisting motion will break the seal and ease removal.
  6. Remove the mounting screws and remove the ignition coil
To Install:
  1. Position ignition coil pack. Install mounting screws and torque to 56 in-lbs. (6Nm)
  2. Connect ignition coil pack electrical connector
  3. Match previously marked spark plug wires to ignition coil and install
  4. Position water shield and install screws
  5. Install RH cowl panel
2helpful
2answers
Removin the plug wires form the spark plugs
HI. This engine was designed with a coil on plug assembly. This means that your power source for the plugs are local(mounted directly on top of the actual plug). This engine dose not have traditional spark plug wires. Each coil has a connector that has two wires running to the connector that is connected to each coil on the engine. Release the coil connector by pushing down on the release clip on the top of the coil and sliding the connector out of the coil female connector. Once the wire connector has been removed from the coil, you can remove the coil from the cylinder port. There is a 10mm bolt that secures the coil to the respective cylinder plug port. Once this bolt is release, you can remove the coil and boot assembly. The actual wires do not need to be replaced.
2answers
Where in the ignition coil on a 2004 ford taurus ses
Ignition coil sit on top of valve cover, follow one of the spark plug wire's, there will be six of them three in the front of the engine on the radiator side and three on the back of the engine next to the fire wall, the spark plug wire will plug right into the coil.Mark your wire's before removing from coil pack so they go back on the same way.
Miss fire 1 and 5 changed wires and plugs
Probably coil pack. Follow spark plug wire from spark plug to where it plugs in, that is your coil pack.Some are seperatable. Depending on motor size you may have coil over plug. You said wires not (cop) coil over plug boots.If it is coil over plug it is just a boot you changed in that case the coils plug into boots & on plug & an electrical connector. They are seperate for each cylinder.
Still running rough after plugs and wires.
if the other coils are functioning, then voltage to the coil pack is ok. removing the spark plug wire from the suspected bad coil with no change in engine performance is a reliable procedure to check for a bad coil.
1helpful
2answers
I have a 2001 ford f150 4x4 .6 triton misfiring
The way that I usually test coils or plug wires is to use an insulated plug wire puller and pull each plug wire (one at a time) to see if the engine speed changes. If you disconnect one wire and nothing changes, you probably have found the defective wire or coil.
You can also use a plug wire tester (neon type) to see if you have a spark. Can also hook up a timing light to a coil wire and it will trigger if coil is good. It will not work if coil is bad.
4helpful
3answers
Coil pack. what and where is it? what does it look like?
Ignition Coil
4.2L Engine
1997-2000
To Remove:
Before servicing the vehicle refer to the precautions at the beginning of this section.
Remove or disconnect the following:
The ignition coil electrical connector
The radio ignition interference capacitor connector
The locking tabs
The six ignition wires, marking for reinstallation
The brackets
The spark plug wire set
CAUTION
Spark plug wires must be connected to the proper ignition coil terminal. Mark spark plug wire locations before removing them.
The accelerator cable bracket nut
The accelerator cable bracket bolt
The accelerator cable bracket and position it aside.
The two ignition coil nuts
The ignition coil stud bolt
The ignition coil
To Install:
Install or connect the following:
The ignition coil
Torque to: 71-98 inch-lbs (8-11 Nm)
The radio capacitor connector
CAUTION
The Spark plug wires must be connected to the proper ignition coil terminal.
Squeeze the locking tabs and connect the six ignition cables.
2001-2003
To Remove:
The spark plug wires, marking for reinstallation
CAUTION
The sparkplug wires must be connected to their correct ignition coil terminal.
The ignition coil
The bolts
Inspect the ignition coil for carbon tracks or damage.
To Install:
The ignition coil
The bolts
Torque to: 53 inch-lbs (6 Nm)
The spark plug wires, in their original positions
4.6L Engine
1997-1999
To Remove:
NOTE: This procedure is for either RH or LH ignition coil.
The radio capacitor electrical connector
The spark plug wires by squeezing the locking tabs (four each side)
CAUTION
The spark plug wires must be connected to their proper ignition coil terminal. Mark spark plug wire locations.
The bolts
The ignition coil
To Install:
NOTE: The procedure is for either LH or RH ignition coil
The ignition coil
The bolts
Torque to: 44-62 inch-lbs (5-7 Nm)
The spark plug wires (four each side), into their original positions by squeezing the tabs
CAUTION
Top of Form 1
Bottom of Form 1
2helpful
Do not know where spark plugs are located in motor
the spark plugs wires are directly located on top of the engine and the spark plugs are down inside the holes in the valve cover itself. I believe there are also 2 coils on top of the engine, which hide two of the spark plug wires which are attached directly to the underside of each coil, remove the coil pull it upward carefully and you will find the spark plugs for those two in the hole underneath the coil for each one. If you decide to replace the plugs, make sure to check the spark plug gap even if they tell you they are pre-gapped as pre-gapped spark plugs are usually gapped for more than one particular car and it may be incorrectly gapped for your specific vehicle. If you decide to also replace the spark plug wires, you will have to purchase the spark plug wires for the underside of each coil seperately because most local auto parts stores only sell 2 spark plug wires in the set that go onto the non-coil attached wires and plugs, and you have to purchase the coil spark plug wires seperately. So all in all you should have 4 spark plug wires, 2 that attach directly underneath the 2 coils, then 2 regular type wires that run to the other spark plugs. If you look at the valve cover and see the wires, you will see what i am saying better. Just don't forget to ask the autoparts store the spark plug gap recommended for you car, and adjust the gap on the plugs as needed. good luck.
Bren H.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
