Acer Aspire One A150-1006 Notebook Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen flickers on Acer Aspire A150 Netbook
Just purchased an Acer Aspire A150. The screen intermittently flickers when the AC power is connected.
If running from the battery the display is fine.
Help!
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Jul 08, 2009
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011048
Points
4641
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Acer Aspire One ZG8 drivers
These are freely available for the netbooks including the aod250 Acer aspire one zg8.
http://us.acer.com/ac/en/US/content/drivers locate model number on rear panel if netbook.
Where is buy a batterie for laptop look at a site www.elecachat.fr
The best place to buy a battery for your laptop is eBay. Once the site comes up just put in the search box something like Acer Aspire One battery. Click the link below and type in the search box "Acer Aspire One Netbook Battery" (without the quotes) and click Search. When the search results come back Select to only see the Buy It Now merchandise and Sort the list by lowest price first. The first couple of items will be ac adapter and power cord, but once you hit the prices in the $20 range you will start seeing the battery. Click the link below
to see a all the batteries.
http://www.ebay.com
The link below will take you directly to one that I selected that costs $23.99 including FREE Shipping. Please note that the battery fits the Acer Aspire One ZG5, A110, A150, D150 and the D250 which is your model.
http://www.ebay.com/itm/New-Netbook-Battery-for-ACER-ASPIRE-ONE-ZG5-A110-A150-5po-/250979671222?pt=Laptop_Batteries&hash=item3a6f8ddcb6
4answers
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
1helpful
I have an Acer Aspire One netbook (model AOA-110) and when i try to boot it up it goes to the boot up screen and brings up a black screen and asks if i want to choose safe mode, safe mode with networking,...
Frequently ACER ASPIRE ONE A110 and A150 hang and give a black screen of death. Most probably this is due to the BIOS problems and if you want to boot them again, a BIOS updating is required.
First, download the required BIOS from the Acer site:http://gd.panam.acer.com/home/ and unzip it by another computer. (Your netbook is already dead!)
Among the extracted files and folders, there is a folder namely Dos_Flash. Open it and there are four file items there like "3310, 3310.fd, FLASHIT, and readme.
Now rename 3310.fd as ZG5IA32.fd and FLASHIT as FLASHIT.EXE and keep the rest as they are.
Copy all these four files to a fully formated and blank USB stick. In this USB stick there should be no other files or folders than what you copied now ( 3310, ZG5IA32.fd, FLASHIT.EXE, readme )
Keeping this USB stick in hand go to the dead netbook. Switch off the device if it is already on. Insert the USB stick. Having the AC power and the battery connected to the device press and hold FN+Esc and simulatneously press the power button to turn on the netbook.
Release the FN and Esc buttons after a few seconds and now the power button will be blinking. In this stage press once the power button alone.
Now the device will start updating the BIOS, we can see the process as the LED of the USB stick flashes. In a few minutes-say less than 10 minutes-the system will restart and come to life again.
Don't disturb it during this process and wait until it comes to full level of operational condition to remove the USB stick.
Best of luck,
M K Pukayoor,
Malappuram Kerala India.
How do you format an acer netbook?
When the acer screen comes up press alt+F10, if it doesn't work then you need to restart your computer again, load the BIOS and enable it.
1helpful
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
1helpful
2answers
My Acer Aspire One A150 screen is damaged and in inverted colours
"I got somebody to replace the screen for me and it was working until now" this more likely affects your warranty as the warranty seal is tampered..
What did the guy do to get it right did you replace something or just got it serviced..??
I don't user acer but my friend had problems with his lap DVD drive n got replacement. It took 2 weeks though
Acer aspire one. 3days old. flickering
Ok if its brandnew and within warranty contact the seller. This should not be happening, to early to give you problem like this.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
