Philips 55PW9363 55 in. Rear Projection HDTV-Ready Television
Problem for Philips 55PW9363 55 in. Rear Projection HDTV-Ready...
The screen is blurry but still works the picture
By cwenzel on Jul 08, 2009
The screen is blurry but still works the picture is not clear
Solution #1
posted on Aug 19, 2009
Not Rated)
James120
Rank: Guru
Rating: 98%, 10 votes
You guys are awesome! I picked up one of your tv repair kits and fixed my TV in less than 1 hour. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Was this helpful?
Yes
No
Solution #2
posted on Jul 22, 2009
Not Rated)
Ecollier2012
Rank: Guru  Philips Televisions & Videos  Expert
Rating: 93%, 569 votes
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
Solution #3
posted on Jul 08, 2009
Not Rated)
hatman1
Rank: Guru  Televisions & Videos  Expert
Rating: 92%, 103 votes
The picture is not clear because the cooling fluid in one or more of the picture tube assemblies has become contaminated. The fluid is supposed to be clear and those units are notorious for having the fluid cloud up after 4 to 8 years. Only solution is to have the assemblies removed and dismantled and cleaned and new fluid installed. This is a lengthy repair as the labor is rather intensive. Most reputable shops charge between $300 and $500 for this job.
Was this helpful?
Yes
No
Popular Solutions for Philips 55PW9363 55 in. Rear
Questions and Unsolved Problems for Philips 55PW9363 55 in. Rear
Do you recommend Philips 55PW9363 55 in. Rear Projection HDTV-Ready Television?
Answer
Answer
color is very off. blue takes over in low lighted picture. I haven't opened the back of the TV up... (More)
Answer
when i plug in hd cable screen is distorted unable to use hd cables
Answer
Problems with Philips 51PW9363 51 in. Rear Projection HDTV-Ready. White colors glow on the TV.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
