Question about Kenmore 24032\24036 Top Load Washer
Model 110.23812100 agitator broken
Our washer filled with water, when it went into the wash cycle there was a sort of grinding sound and the agitator won't move. I cycled it to spin and still nothing, although the water drained itself. I am also unable to spin the tub or the agitator manually. Please help
  • 1 more comment
  • Frank K Nov 13, 2007
    thanks Mike, did everything suggested and found the piece connected to motor broken, rubber and other piece were in tact. I'll get the replacement tomorrow, should I go ahead and replace all three pieces while it's broken down?
  • barrymac Nov 17, 2007
    how those the washer come apart. do i got to take off the dryer first or what thanks.
  • Anonymous Mar 19, 2014
    will fill and drain water but when wash or spin cycle it sounds like it is trying to work but nothing is moving at all. can't rotate tub by hand
  • 290 Answers
You probably have a broken motor coupler.
Pop off the trim pieces on the front edges of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
You can get a coupler for about $10.
If it breaks again in a few months, then there probably is a problem somewhere in the transmission or basket drive.
Post back if you have any questions.
Posted on Nov 13, 2007
  • Michael  Lindley
    Michael Lindley Nov 13, 2007
    Yes, replace the complete coupler. It all comes together as a set. The new one you get should have a steel center to keep it from wearing out the plastic as quickly. That is something they just changed in the design recently.
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
The part number is included in the link I provided. You can purchase a replacement on line at for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Oct 04, 2009 | Roper RAX7244KQ Top Load Washer
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
Washer fills with water but will not agitate to wash the clothes.
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
258 people viewed this question
Sal De
 Brian Main
Brian Main
