Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to keep TV on digital?
For the second time in three days, I've accidentally hit some button that switches the TV from digital to analog. My friend fixed it the first time. Now, I'm stuck again. I've pressed every button I can, but I can't switch it back to digital and there's no picture.
    Problem Solver:
  • 8 Answers
It depends a little bit on your setup but sounds like you may have drifted from an external source to the television's internal tuner.
On my slightly different Aquos model my digital channels are "Ext 5" and "Ext 6".  There is a button next to the digits that is a square with an arrow pointing into the inside of the square.  This can be used to cycle through the external analogue and digital sources.
Push the button and then leave it for about 5 seconds as it can take a while before an image is displayed.  Keep pushing the button until the right digital channel is displayed.
Posted on Nov 18, 2007
WHAT is this tv digital ?
Dear Friend,
First, search for available air channels by going to you menu and then search for channel setup.
Second: change the option from Cable to Air Channels.
Third: after performing the channels setup you should be able to see free channels trough the air.
Good Luck!
Aug 06, 2014 | Shopnbc Insignia 39", 46" or 55" Full HD...
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I own a mad catz n64 controller and any time i push or hold any button (b,a, cs) it makes the character move slightly but endlessly to the right side, the control stick works fine, i only got this problem...
To remedy this, simply don't move the analog stick when powering on the system. When the system turns on, however the analog stick is set to be the default center so if it is moved, it is assumed to be the normal center position. If you have accidentally moved it while powering on the system, you can reset it but letting the analog stick reset to center and then press and hold START, L and R at the same time for three seconds.
Jul 18, 2011 | Nintendo 64 Console
Accidentally hit wrong button on remote and it switched tv from analog to digital, can't find a way to switch it back
Try going to the menu and changing it back from there! If all else fails then just keep pushing every button on the remote and im sure you will hit the right one!!!!
GOOD LUCK!!!!!!!!!!!!!!!!!!
HAPPY HOLIDAYS!!!!!!!!!!
Dec 23, 2010 | Sylvania SST4322 32" TV
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
191 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
