Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Battery door stuck
Shut door and wont open
One rear passenger door will not open from inside or out in Vauxhall Astra
Help! Door wont open! [Archive] - Astra Owners Network Forum ' MK1 ...
www.astraownersnetwork.co.uk > ... > Astra Chat > Astra H
Nov 29, 2009 - 31 posts - ‎16 authors
my rear passenger door is stuck shut but all the other doors open ok. i ... the insideby pulling the chrome handle, it will not open from the outside. ... the battery again after the fixed wire. strange vauxhall thing, some times even ...
Oct 30, 2015 | Vauxhall Cars & Trucks
Passenger side electric door latch stuck shut and wont allow me to close door. seatbelt got caught in door when i was trying to shut it.
unhook battery for five minutes and reinstall should trip or manually move it while battery diconnected
Mar 10, 2015 | 2001 Dodge Grand Caravan
Dyer light out and door switch wont shut dryer off hen opened door
the switch has a push button on it it may have gotten stuck in a closed position best to replace it. Also check the mechanism that attaches to the switch it may have gotten bent you might try straightening it or just replace it. the switch should have three wires to it and is located by door
Sep 15, 2014 | Dryers
How to open a stuck door on 96 chevy 1500
A mechanics worst nightmare. You have to somehow remove the door trim on the inside to get to the latch and lock mechanisms to release them manually to open the door. Hard to explain but thats basically the idea. Keep in mind that there are probably plenty of replacement door trims in the junkyard so don't be afraid to damage the one you have to gain access.
Aug 30, 2014 | 1996 Chevrolet K1500
Battery door stuck
ADD SMALL AMOUNT WD40.WITH COTTON BUD
Sep 14, 2013 | Health & Beauty
Rover75 52plate door stuck
52 plate ?? is this a sit up and beg type rover 75 ,you know the big thing with the bench seat and handbrake between the door and seat?
Mar 12, 2013 | 2000 Rover 75
My 91 chevy truck is stuck open
SOUNDS LIKE LATCH WAS IN CLOSED POSITION WHEN DOOR WAS SHUT I'VE HAD IT HAPPEN A FEW TIMES PUT A SCREWDRIVER IN THE LATCH OPENING AND PRY WHILE PULLING INSIDE HANDLE...IT MAKE TAKE A TIME OR TWO
Oct 11, 2012 | Chevrolet Cars & Trucks
PASSENGER REAR DOOR WILL NOT SHUT STUCK OPEN?
hello,seems your door brake is stuck-up,remove your door siding,then put some grease or replace your door brake,ty
Apr 26, 2009 | Mercedes-Benz E-Class Cars & Trucks
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Feb 10, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
107 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
