Cars & Trucks Logo
A
Anonymous Posted on Feb 28, 2015
I have 2006 chevy equinox code po455 I change the fuel cap and the purge evap valve but my code comes back what else could it be?
2006 chevy equinox error code po455. I change the fuel cap and the purge valve. what iles could it be?
Daniel OConnor
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 10, 2022
Daniel OConnor
Contributor
Level 1:
Answers
Questions
0
Helped
2087
Points
High pressure fuel pump on intake manifold is the cause. Replace it and clean/lube internal piston
ittco
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Mar 01, 2015
ittco
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
5490
Points
26
As you know one of the problems can be the Fuel Cap. I make this suggestion. If you changed your Fuel Cap before the Purge Valve double check that the cap used was an OEM (Original) Chevy Part for that specific vehicle, not just any cap from another Chevy.
2answers
I would like to know what the code PO455 on a 2007 Mitsubishi Endeavor means.
Possible causes
- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
help.jpg What does this mean? Tech notes
The P0455 it's a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
help.jpg What does this mean? When is the code detected?
Evaporative Emission System (EVAP) control system has a very large leak such as fuel filler cap fell off, EVAP control system does not operate properly.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors
P0455 Mitsubishi Description
This diagnosis detects leaks in the Evaporative Emission System (EVAP) purge line using engine intake manifold vacuum. If pressure does not increase, the Engine Control Module (ECM) will check for leaks in the line between the fuel tank and EVAP canister purge volume control solenoid valve under the following vacuum test condition.
The vacuum cut valve bypass valve is opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP canister vent control valve will then be closed to shut the EVAP purge line off. The EVAP canister purge volume control solenoid valve is opened to depressurize the EVAP purge line using intake manifold vacuum. After this depressurization is implemented, the EVAP canister purge volume control solenoid valve will be closed.
Read more: http://engine-codes.com/p0455_mitsubishi.html#ixzz3NlVyARyX
Codes0441 0442 0455 0456
codes po441 po442 po455 po456. code po441 - EVAP system no flow during purge conditions.code po442 -EVAP system small leak detected conditions. code po455 - EVAP system large leak detected conditions.code po456 - EVAP system very small leak detected. possible causes loose damaged missing fuel cap.fuel tank sensor disconnected or failed. ORING on top fuel sending unit leaking.purge valve vapor line clogged disconnected or purge solenoid failed.vent solenoid not closing or has failed.
1helpful
2000 Ford Focus...DTC code PO455
code PO455
EVAP Control System Large Leak Detected
Possible Causes:
Aftermarket EVAP hardware non-conforming to specifications Canister vent (CV) solenoid stuck open EVAP canister purge valve stuck closed, or canister damaged EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged Fuel filler cap missing, loose (not tightened) or the wrong part Loose fuel vapor hose/tube connections to EVAP components Purge sensor or FTP sensor is out of calibration or has failed I would say that your gas cap is a good place to start.
3helpful
Engine light on po455
CODE PO455 - EVAP SYSTEM LARGE LEAK DETECTED. POSSIBLE CAUSES. FUEL FILLER CAP LOOSE. PURGE SOLENOID VALVE IS DAMAGED OR HAS FAILED. CHARCOAL CANISTER IS LOADED WITH FUEL OR MOISTURE OR HAS FAILED. CANISTER DRAIN CUT VALVE CDCV IS DAMAGED OR LEAKING. FUEL TANK PRESSURE SENSOR IS DAMAGED OR HAS FAILED.CATCH TANK OR ROLLOVER VALVE IS DAMAGED OR FUEL TANK IS LEAKING. VAPOR LINES DAMAGED OR LEAKING BETWEEN THE PURGE SOLENOID AND INTAKE MANIFOLD PURGE SOLENOID AND CANISTER OR BETWEEN THE PRESSURE CONTROL VALVE.CHECK VALVE AND ROLLOVER VALVE. PCM HAS FAILED.
What does the code P0455 mean on a 2006 Galant
PO455- EVAP System
Gross Leak or No purge Flow
Gas Cap -Bad or just not on tight
Cracked Hoses
Purge Valve Stuck Closed
Canister Vent Solenoid Stuck Open
Fuel Tank Pressure Sensor
Check that gas cap is on, then after that
a repair shop
2helpful
Check engine light came on while I was driving back from LA. had a lube and oil change and the mechanic said my code was PO455. light is off now but what did it mean? low oil? etc? thanks.
CODE PO455 IS EVAP SYSTEM LARGE LEAK 0.080 DETECTED. POSSIBLE CAUSES FUEL FILLER CAP LOOSE CROSS THREADED OR INCORRECT PART. PURGE SOLENOID VALVE IS DAMAGED OR HAS FAILED. CHARCOAL CANISTER IS LOADED WITH FUEL OR MOISTURE OR HAS FAILED. CANISTER DRAIN CUT VALVE CDCV IS DAMAGED OR LEAKING. FUEL TANK PRESSURE FTP SENSOR IS DAMAGED OR HAS FAILED. CATCH TANK OR ROLLOVER VALVE IS DAMAGED OR FUEL TANK IS LEAKING.VAPOR LINES DAMAGED OR LEAKING BETWEEN THE PURGE SOLENOID AND INTAKE MANIFOLD , PURGE SOLENOID AND CANISTER OR BETWEEN THE PRESSURE CONTROL VALVE, CHECK VALVE AND ROLLOVER VALVE. PCM HAS FAILED.
2helpful
2answers
Code po455 engine light, replaced gas cap, replaced missing bolt on cap that houses air filter. not registering a o2 bank. whats with this pcv valve or ftp control module. is this what i need to have...
it sounds like you have a problem with the evap system which has to do with emissions for the fuel vapour system so raw fuel vapours won`t vent to the atmosphere and instead is drawn into and burnt by the motor.there is hoses,control valves,vent valves,canister,purge valves,gas cap, any one of these could be the problem.you will have to have the system tested at a shop to find the cause of the problem.
14helpful
2answers
What is code 455 (Check engine soon light) on my 2004 Chevy Trailblazer, 4.2l
CODE PO455 - EVAP SYSTEM LARGE LEAK DETECTED CONDITIONS.POSSIBLE CAUSES FUEL CAP LOOSE MISSING,FUEL TANK FULLER NECK OR FUEL SENDING UNIT O - RING IS LEAKING, FUEL TANK PRESSURE SENSOR IS DAMAGED,FUEL TANK VAPOR LINES,CLOGGED,DAMAGED,OR DISCONNECTED,PURGE VALVE VAPOR LINE IS CLOGGED,DAMAGED,OR DISCONNECTED,PURGE SOLENOID IS NOT OPENING,IT MAY BE DAMAGED OR STICKING,VENT SOLENOID IS NOT CLOSING,MAY BE DAMAGED OR STICKING,PCM HAS FAILED.
9helpful
2answers
Mitsubishi 98 faulty fuel cap, leaking vent or purge solenoid, evap hose faulty, leak on fuel tank, PO455
Mitsubishi 2006 faulty fuel cap, leaking vent or purge solenoid, EVAP hose faulty or leak on fuel tank.... replace the fuel cap and a week later the light was back on...the code is P0442..what to do next
4helpful
2answers
What is he code 455 for a 2006 hyundai sonata means
CODE PO455 EVAPORATIVE EMISSION SYSTEM LARGE LEAK DETECTED.POSSIBLE CAUSES CANISTER VENT SOLENOID MAY BE STUCK IN OPEN POSITION / EVAP CANISTER TUBE EVAP CANISTER PURGE OUTLET TUBE OR EVAP RETURN TUBE DISCONNECTED OR CRACKED OR CANISTER IS DAMAGED / EVAP CANISTER PURGE VALVE STUCK CLOSED OR CANISTER DAMAGED / FUEL FILLER CAP MISSING LOOSE NOT TIGHT OR THE WRONG PART / FUEL VAPOR HOSES TUBES BLOCKED OR RESTRICED OR FUEL VAPOR CONTROL VALVE TUBE OR FUEL VAPOR VENT VALVE ASSEMBLY BLOCKED /FUEL TANK PRESSURE SENSOR HAS FAILED MECHANICAL FAULT /FUEL TANK CONTROL VALVE IS CONTAMINATED DAMAGED OR HAS FAILED.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
