Question about EliteGroup P4VXASD (P4VXASD-R) Motherboard
Wont boot For a while it would not boot XP until I reset two or three times. One short beep but no windows until I reset or turn off and on again.I changed the RAM and power Supply.Now I get three long beeps and nothing.
  • 134 Answers
I think there is a problem with the pin connection of the RAM. Remove the RAM again, then clean the pin with the contact cleaner spray then plug in again. do same thing with the CPU/processor if necessary. if you got One short beep when boot windows the problem haven't from hardware but on your system. try to run scandisk, disk cleanup, or press F8 while booting to go into "safe mode". Hope this be of some help/idea. Pls post back should you need additional information.
Posted on Nov 13, 2007
When i turn my computer on it has a long beep sound and then another long beep and wont quit... please help
Check your MEMORY MODULES . Try removing them, cleaning them with rubbing alcohol and the reinstalling them. Re-boot. That should work, ok?
Oct 18, 2010 | Acer Computers & Internet
Quite awhile ago, one side of the unit went dead. Uesterday, after hearing a couple clicks, the unit will beep a few short beeps, then after a little bit, there will be a few short beeps again. I press the...
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
Mar 09, 2010 | CyberPower 525SL (CPS525SL) UPS System
My computer at start up beeps 3 times and won`t boot
Try booting up in safe mode. Press power on button and press F8 until you see a list appear. Go in under safe mode and see what the problem is....Hope this helps....
Nov 17, 2009 | Microsoft Windows XP Professional With...
HP dv6000 Laptop screen only starts up 1/4th of the time
The first issue you had with one long beeps and two short beeps is a memory module error. see the following HP website: I would replace the memory chips and try again. If you have more than one chip try booting with one at a time to discover that one of them may be bad.
Jun 14, 2009 | Computers & Internet
My acer travelmate wont boot just beeps 4 times i recently reinstalled XP Pro os on acer ferrari 4000 and have recieved this same problem 4 beeps and black screen.won't boot..bios or os. HELP
I long + 3 short beeps or 3 short + 1 long beeps indicates memory problem.
The RAM module/s may need reseating to re-establish proper electrical contact.
If it still doesn't boot up then :-
Get the RAM module/s may be faulty, test the module/s in another laptop or get your friendly computer shop to test them.
May 07, 2009 | Acer Ferrari 4000 Laptop Notebook
My PC auto matically restart when turning it on
The beep you hear is your BIOS trying to alert you to an error in the POST (power on self test) routine. Without knowing the manufacturer of your motherboard one can't be certain what the beeps indicate...see this link for more info:
It's possible you have some kind of infestation, and it's possible there's something more systemic, but without knowing the make and model of your system I couldn't say.
Sometimes three beeps indicates a keyboard could try another keyboard or unplug yours and see if it will boot up "normally" without it.
Otherwise, report back with some more info and we'll take it from there.
Mar 28, 2009 | Microsoft Windows XP Home Edition
Cpu beeping
do you mean you cpu have problem booting up?
if yes check your ram take them out and put them back in again.
Feb 01, 2009 | Microsoft Windows XP Media Center Edition...
I have a DFI AM75-TC motherboard, 3beeps, no video
Hi richardbyers, three short beeps means there is a problem with your memory. (Base 64K memory failure). Unplug the power from the PC. Open the case & touch the bare metal on the case to discharge your self.
Remove the memory & reseat it. Leave the case opened & re-connect the power cord & try booting again. If you still hear three short beeps, shut the system down again as mentioned above. Gather some house hold alcohol & a couple cotton swabs. Drip a drop or two onto a cotton tip & wipe the memory's contacts, both sides & do not touch the contacts with your fingers during re-install or cleaning. Blow the memory slots out with canned air or use a clean paint brush. Insert the memory again & connect the power cord. Boot the PC. Try this first. If everything works out than good. If the problem does not clear its self let me know.
Good luck richardbyers!
Jan 06, 2009 | DFI AM75-TC Motherboard
Hp 9695c wont boot only ht HP banner shows but wont go to the initialization
Press and hold down Shift key, when you hear the beep, until system boots.
If you dont time it right you will get a keyboard error, dont worry, just press F1 key and immediately hold your Shift key again.
Your system should boot into basic mode, then you need to check your system for virus or last software that may have been installed.
Nov 25, 2007 | HP Pavilion dv9000z Notebook
Wont boot
seems contagious mine did the same thing!not sure how helpful this will be but the bios handles the starting up part and if it's corrupt then that wont happen.If you can get the bios flash that you need onto a floppy then that might help at the moment I'm waiting for a new bios chip.Did you receive any errors at all ?awdflash.exe? insert disc etc ?
Aug 16, 2007 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
EliteGroup P4VXASD (P4VXASD-R) Motherboard Logo
119 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
