Question about Microsoft Windows XP Home Edition
Slow in opening file or program
I am using a windows xp home edition, but everytime I double click an icon to open a file or run a program, my computer hangs-up for about 30 - 40 seconds before it execute. I already clean-up and defrag my registry and hardrive several times but the problem still persist. The only program the run at start-up is the AVG anti-virus, windows defender, and mcafee site advisor. does all this program cause the slowdown? what must i do to speed-up opening a file or running a program?
    Genius:
  • 1,601 Answers
what model computer do you have?
cpu
ram
hd
do you need avg and mcafee? they might conflict
Posted on Nov 13, 2007
  • Thomas Christopher
    Thomas Christopher Nov 14, 2007
    Spyware can also slow your computer because it uses memory resources. Try downloading and run spybot and adaware.
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
When i go to log in on my pc a notice comes up saying i need to reinstall framedyn.dll but dont know how
  1. Open your default Web browser. Search the Internet for a download location for a working version of framedyn.dll, or just follow the link in the Resources section below to download it from a reliable location.
  2. Click the download link and follow the prompts that appear onscreen to save the file to your hard drive. When the file finishes downloading, double-click it to open it in your computer's default program for compressed files. Click the "Extract" or "Unzip" button in this program, and select your desktop as the destination for the file when prompted. This will extract framedyn.dll to your desktop.
  3. 3 Double-click the "My Computer" icon and browse to the Windows system folder. The exact location of this folder varies among the different versions of Windows. In the original 32-bit versions of Windows XP and Vista, the system folder is located at "C:\Windows\System32." If you're using the 64-bit versions of Windows XP or Vista, navigate to "C:\Windows\SysWOW64" instead. If you're using Windows NT or Windows 2000, look for "C:\WINNT\System32." In the oldest Windows operating systems that use this file, including Windows ME, 95 and 98, the system folder is located at "C:\Windows\System."
  4. Left-click and hold the framedyn.dll file on your desktop and drag it into the system folder. Release the mouse button. If the original framedyn.dll file was missing, you won't see any Windows prompts. If it is present but corrupted, you will see a Windows prompt asking you if you would like to replace the existing file. If this happens, click "Yes."
  5. Reboot your computer.
Nov 05, 2010 | Microsoft Windows XP Home Edition
I am trying to install my old software on my new computer. After hitting the "Install personal patterns for children - special edition" I get an error message stating: could not execute external program...
Open "My Computer".
Double-click the icon for the CD-drive.
Look for that 'ppchild' file.
Or, look for an 'setup' file or an 'install' file.
Double-click one of those files, to restart the installer.
If it still fails, then your new computer (running Windows 7) probably has recognized that the program is _NOT_ compatible with Windows 7. So, start the Windows "Program Compatibility Wizard", and tell it that you want to install a Windows XP program on your new computer.
Sep 22, 2010 | TOPICS Entertainment Instant Stitch...
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
I can't open a wmv file attached to an email by double clicking on the attachment. It says that it does not have a program associated with it. When I copy the file and then double click it it runs a Spybot...
right click ..than properties ..,than change the file associations..and choose the windows media player as default player for this kinda files...it behaves like this cause it do not remembers the file associations...
Jan 14, 2010 | Microsoft Windows XP Home Edition
Downloading photos from Canon 400D direct to Canons photo editing programmes on new windows Vista computer.
There are two ways to solve this problem. I am assuming you are simply clicking on the pictures and choosing "edit" or double clicking on the pictures and they are opening in "Vista picture editing"
The first way to overcome this is by opening the desired program first (in this case canon's photo editor) and then choose open and find the desired photos.
The other way is to set the file type association in vista so that RAW programs open with the canon program see below for step by step:
1. Click Start
2. Click default programs on the black bar
3. Click Associate a file type or protocol with a program
4. Find the file types you want to open automatically in your canon editing program (RAW .jpg etc)
5. Click once at the top of the page click change program
6. A new window will open, if it does not list the correct program click browse at the bottom of the window and find your editor in it's folder.
7. Select the desired program by double clicking
8. Click OK
9. Click close
10. Test the new file association by double clicking a RAW file or one of the other file types and see if it loads into the correct program.
The final (and this is simply my plug for open source programs) solution would be to try something like GIMP (it is a photo editing suite developed under linux but adapted for windows) you can search for it on google.
If you are having trouble with any of these steps please post a comment and I will try and add some clarification.
Hope this helps
May 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cannot see my desktop
Please try these steps to solve your problem:
1) Press Ctrl+Alt+Del to run the Task Manager
2) Click on "File" on the Task Manager upper menu
3) Click on "New Task (Run)" option, Run window should appear
4) Type "explorer" without the quote, on the Run window
5) Your start menu and icon on desktop should now appears
hope it helps :D
Apr 29, 2008 | ASUS A9RP Notebook
Xp updates... about 56
They are suposed to be there, note there is a checkbox in the windows witch reads, show updates.
Mar 25, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
75 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
