All fuses okay. Replace turn signal switch on column first, did not help turn signal hazard relay fixed problem for 20 minutes of driving then right quit again.
Sounds like you have a wiring issue ! Maybe when you installed the turn / hazard relay you moved the wiring harness in such away that made it work. Grab the wiring harness an do the wiggle test an see if it works . Mite have lose connection where the relay plugs in, close the terminals a little bit. I don't know what you know about electrical systems on automobiles or I'd tell you to do a voltage drop test to find the problem . Need volt ohm meter an a wiring diagram to do this test. Electric Testing Techniques You Need to Know
