1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hoover Nextra HNF 2137 Front
hello the door locks and then the door light just keeps flashing on my hoover nextra washing...
(More)
hello the door locks and then the door light just keeps flashing on my hoover nextra washing machine. the machine wont start. any help please????
Hi
we have detergent blocked in the pipe from the detergent drawer....
Have you any advice in...
(More)
Hi
Have you any advice in hoe to unblock it as hot water doesn't work
thanks
