Will not turn off. Must take out battery to shut down the device.
SOURCE: Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
SOURCE: Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
SOURCE: Garmin Vista Shutting down and freezing up
People! The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
SOURCE: wrong language on garmin oregon 400t
I called Garmin for this very same reason. The answer is; while your GPS is off place your index finger in the upper left of the screen, turn on the GPS, a screen will come up and ask if you want to clear the GPS (or something to that effect), say yes. (Yes is the top button) Then you can choose english. YAY!
Rin
SOURCE: Garmin Nuvi 200w Flashing screen "Garmin Logo" will not turn off
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Do a RESET:
The reset button on your nuvi 2xx, 3xx or 6xx will not restore your
device to factory settings or delete any map updates. The reset button will
switch your device off if you are unable to switch the device off by the power
button. It will not erase any data on the device.
The reset button on your nuvi will switch
the device off. The reset button can be used to switch your device off if the
screen is frozen and you are unable to switch the device off by the power
button.
To reset a nuvi 2xx:
To reset a nuvi 3xx or 6xx:
The device will now switch off.
