Question about Roper REX5635E Dryer
Electric cooker not working.
I have Black & Decker electric rice cooker. It stopped functioning today. After I plugged it in, the light is not on. When I pressed the knob for cooking, the knob doesn't stay and the cooker doesn't work. If any of you know any solution for this, please let me know.
Thanks
Manohar
  • rrotte Dec 27, 2007
    BLACK AND DECKER 6 cup electric rice cooker stopped working suddenly. Unable to see the light when we plug in to the knob.
Thermostat unit need to be replaced...
Posted on Oct 04, 2010
How do i fix my black and decker rice cooker? steamer. The cooking light doesn't come on and the heating element doesn't heat.
check that the socket/outlet is working. check that the cord is functional. post what you find as a comment to this question/answer pls
Jul 17, 2015 | Kitchen Appliances - Others
Rice Cooker not working
Return to shop if you have only used it 3 times. This a faulty.
Mar 13, 2015 | Applica Black And Decker 6 Cup Rice Cooker...
I put rice to cook and i smelled something burning. When i checked the rice cooker, it wasnt working at all. All the lights went off and i checked the other power supply, it was still not working...
have your rice cooker replace for another new rice cooker ( to make sure, because it might be an internal short circuit) then call an electrician to check your electrical wirings.
May 12, 2011 | Black & Decker Black Decker RC5428 28Cup...
The swith is not working and no light is coming in the cook or warm mode.
first try to remove the pot, then push the button in middle of the ricecooker..if th cooker light turn on then the problem is the spring..try to open your rice cooker, you will see the spring inside, try to stretch the spring
Aug 30, 2010 | Black & Decker Black Decker RC3406 6Cup...
Power is not going though
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jul 05, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Black and decker flaver scenter rice cooker manuel
http://www.useandcaremanuals.com/pdf/HS80035.pdf
is the pdf of the manual for this product
Sep 09, 2009 | Black & Decker HS800 Flavor Scenter 4-Cup...
Black & Decker rice cooker not working
Check the outlet where u plug in the rice cooker. It could be that the circuit breaker has kicked off or the fuse has blown. let me know how you make out. If that isnt the problem I have additional suggestioins
May 20, 2009 | Black & Decker RC550 10-Cup Rice Cooker
Rice cooker
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord.  make sure those two are both working good.  next step is to open the Rice Cooker Bottom.  Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective.  Which is the reason why your cooker is not turning on is due to an open in the circuitry.  Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Aug 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Dryers Logo
121 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
