Question about Samsung Digimax S630 Digital Camera
Power wont stay on
My S630 will not power on. I have tries fresh alkalines batteries and also freshly charge NiMH. When I press the power button on top the green light comes on for half a secong and then nothing. By the way, my lens is currently stuck in the extended position. Please help!
  • 1 more comment
  • Anonymous Nov 14, 2007
    my camera just don't turn on i try new battery is not a work
  • saumil Apr 10, 2008
    Hello, I seem to have the same problem...
    - new set of alkaline batteries installed
    - pressed the power button
    - camera beeps 3 times and shuts down
    So, can' t even get to the 'Menu' option!
    Kindly help; thank-you in anticipation.
  • manda_c Apr 17, 2008
    well my camera turns on for a sec then beeps 3 times and shuts off.
  • 75 Answers
Remove batteru for a minute and insert it again. There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set Up 2 (icon looks like a wrench with number 2 on it)
- Scroll down to Battery Type
Under Battery Type, there are two options:
- Alkaline- if you are using non- rechargeable battery
- NiMH- if you are using rechargeable battery
Posted on Nov 30, 2007
Olympus ws500m wont charge to computer
It's not supposed to. The WS-500m uses standard AA batteries, either disposables or rechargeables. If you want to use rechargeables, you must charge them outside the recorder using a separate battery charger.
Sep 15, 2012 | Olympus WS500M (2048 MB 5445 Hours)...
Alarm
that means your batteries are not charged fully. I'm assuming you have new fresh batteries? Does the panel stay up long enough to show the charge level?
Feb 16, 2008 | Samsung Digimax S630 Digital Camera
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
I have loaded 4 new AA batteries and try to take a pic and "battery empty' appears in scrren and will not take a picture.
Be sure to have real fresh alkaline AA of fresh recharged NiMh batteries.
Good rechargeable batteries are Sanyo ENELOOP NiMh batteries, which have a very, very low own discharge. Some other brands have them too.
May 05, 2011 | Olympus SP600UZ Digital Camera
I changed my batterys and now it wont let me talk or hear threw the mic
What type of batteries did you use? It's best to use new, fresh from the package alkaline AAA's. You can use NiMH rechargeable batteries, but make sure that they're fully charged up. Some say they come fully charged, but they might not be.
Jan 06, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
My samsung digital camera lens will not stay open,nor take pictures,blurry lens
Make sure the batteries are fresh alkaline batteries. If this doesn't work and the lens is clean i would be 90% sure that the focusing motor is gone. Has it gotten any knock or drop resently? It only takes a little one!
Aug 14, 2009 | Samsung S630 Digital Camera
My vivacam kills batteries within a few minutes
Do not use alkaline batteries. Buy NiMH rechargables and keep a couple of sets on hand fully charges. ViviCam's eat alkalines alive!
Apr 25, 2009 | Vivitar ViviCam 5100 Digital Camera
Change batteries message pops up with new batteries
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Jun 23, 2008 | Canon PowerShot A85 Digital Camera
Batter Life
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
Kindly regards,
micro
Feb 28, 2008 | Samsung Digimax S630 Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
89 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
