SOURCE: philips lx3600d
Common problem with the Philips - here is how to fix this issue:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
SOURCE: How to play TV sound through Philips Mcd288
You must plug the t.v. audio out cables into an audio input on the philips. left and right audio rca jacks. then you must select that input on the philips to hear the tv. Lawrence
SOURCE: NO SOUND
Gordon Brady says - go to the 45 Field Support Squadron Reunion in May 2009 and all your problems will be solved. Contact me at gordon brady at hot mail dot com for details please Kev.
SOURCE: Remote Codes
Hi which universal remote do you own?
You normally can find the codes on their helpdesk site.
For philips:
http://www.urc.philips.com/
SOURCE: How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
