Question about Dual XD-7500 CD Player
Power...but no sound...help
I have all the wires connected correctly, it turns on, off...ejects....plays the cd.....but no sound....maybe a soldering problem? lemme know if you have any ideas....
thanks
  • 2 more comments
  • meoddity Nov 13, 2007
    lol...no the mute isnt on.... i think it may be internal.....but just not sure
  • meoddity Nov 14, 2007
    i have a 1979 vw bus....so i have no adapter harness for it....maybe thats my problem...
  • swehling Dec 31, 2008
    i have power but no sound same thing you described and i have the harness its a newer dodge ram
  • Anonymous Feb 02, 2009
    i notice that if the face doesn't close all the way it would operate right, there is a little plastic cork screw in the unit, but you'd have to take the top cover off and see if its strip, it turns the other gears that lower the face, i havent been able to replace that part, so i just use the radio
  • 85 Answers
Simple long shot question... Is the mute on?
Posted on Nov 13, 2007
  • Shawn Bowman
    Shawn Bowman Nov 13, 2007
    I use to install stereo's myself all the time. I would recheck the wiring.. I noticed if you have a factory headunit wire harness going into the ADAPTER harness for the car.. some times the wires in the harness itself is mixed up.
Take a long piss on it!
Posted on Dec 09, 2007
Vw polo 6n cd player has power but does not light up or play music
what color is the wire..it may be a memory lead..yellow or orange..some even have a power wire to the antenna so it will raise when the power is turned on..also may check the switches inside the unit that work with the eject part of the system..
Dec 28, 2013 | Volkswagen Cars & Trucks
Will not eject disc and when i push the power button it turns off on its own
hello,
Could be a few reasons for this. If it's been dropped, the cogs could be misaligned, you will need to take the CD unit apart and reassemble correctly. If someone has attempted to fit a mod chip there could be damage around the part of the board where the wires for pins 5 & 6 are soldered. Check for damage to tracks and excess solder, it is also possible that the BA8510 or BA8515 chip has been damaged. Also it could be the flat flexible cable that connects the power/reset & eject buttons to the main board. Check for physical damage and replace if need be.
May 29, 2010 | Sony Playstation 3 (PS3) Console
We installed a jvc kd-s26 into my 2002 trailblazer, I believe correctly but the radio will only turn on for about 15 seconds and then powers off.... I do not understand
There are two power wires for the receiver. One will light the clock and eject the CD when the eject button is pressed, but will only stay on a few seconds and this is connected to a battery source. The other power wire actually turns on the radio and is connected to a source controlled by the igition switch Check the wiring diagram to see if you have both wires connected correctly.
Feb 02, 2010 | JVC Car Audio & Video
Radio wiring hook up
SOUNDS LIKE THE EJECT BUTTON IS STUCK ON, TRY TAPPING ON THE EJECT BUTTON OR RECHECK THE WIRING TO MAKE SURE THAT YOU HAVE ALL THE WIRES IN THE CORRECT SPOTS. ALSO CHECK TO SEE THAT THE GROUND WIRE ON THE BACK IS CONNECTED AS WELL. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
May 02, 2009 | 1989 Honda Civic
Just installed KD-SH55 JVC in Tahoe myself, no lights on but ejec
if it has a face plate and most after market radios do then it may not have a good connection check and make sure it does maybe even clean them with alcohol also make sure you got a good ground it may not have enough power to come on all the way (<-- rarely is the case) but it sounds like a bad radio
May 01, 2009 | JVC KD-SH55 CD Player
Twice my Pioneed DEH-P7900BT has just stopped working. Keyboard went dark and the unit shut off. I pressed the button to open the face place and it opened and is stuck that way. It also didn't eject my CD...
This sounds like a wiring problem. Double check all of you connections. If the Connections look good then I would check the connections inside the radio. Check the power wire mostly. The wire could have a bad solder joint inside the radio itself.
Mar 02, 2009 | Pioneer DEH-P7900BT CD Player
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
I have a problem with the CD player turning on.
sounds like u got a bad unit if only certain things get power then it sounds like an internal problem
Jun 25, 2008 | JVC KD-G200 CD Player
Stereo will not operate correctly
did you try running a ground wire from the case of the deck to the battery,just for testing?
Feb 04, 2008 | Kenwood KDC-MP435U CD Player
Reconnecting Deh - P3000
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
Jul 18, 2007 | Pioneer DEH-P3000 CD Player
Dual XD-7500 CD Player Logo
101 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
