Sounds like motor is not turning drum....could be due to worn motor brushes, you need to remove the motor to check this ,if not too handy advise you call engineer........
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
check your filter. Could be an eratic pump. Dispening draw needs to be cleaned and make sure the small hole is clear to allow the conditioner to flow through
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
