Question about Moultrie Cameras
Game camera needs help(River Flooded)
I have a Moultrie Feeders Game Watcher 35mm Infrared Photo Surveillance System. I had it set up on a tree about 1/2 a mile off of a river. I removed the camera after hunting season to change film and batteries. When I returned about 2 weeks later to put the camera back inside the box that was mounted on the tree, I realized that the box had been under water. Anyway I took everything back home and everything inside the box was muddy and rusted. Problem : I cut the wires going to the battery box, the infrared light, and the computer board. I need a wiring diagram or someway to know what wire goes where. I am going to replace the small battery boxes and clean up the board. What can I clean up the computer board with, without hurting it? After all the work, is there anyway to check and make sure it still works? Thanks for any help!!!!!!!
SOURCE: 2002 Chrysler Sebring will not start
Mine did the click, click and the timing chain had snapped. If any of you have 2.7 litre engines plan on an engine rebuild or a replacement. Look up the 2.7 engine size along with oil sludge and timing chains. Grab yourself a towel to sop up the tears. This car is 100% garbage and I'm shopping for another non Chrysler product this week.
Posted on Oct 14, 2008
  • 51 Answers
SOURCE: need a online wiring diagram for a 2003 yamaha 225
Posted on Sep 12, 2009
SOURCE: Wiring for Bosch Hologen Fog Lights? Wiring
Look on the relay for the terminal numbers.
Terminal 30 goes to the battery positive.Red Wire
The two terminal 87 go to the fog lights.Black Wires
Match the color wire with what you have on the relay connection for the rest of the wires.
Terminal 86 should connect to your low beam headlight.
Terminal 85 should go to the fog light switch.
The fog light switch should connect to the terminal 85 and the other terminal on the switch will connect to ground.
Posted on Feb 04, 2010
  • 296 Answers
SOURCE: moultrie 5.0 outfitter camera with infrared flash
Posted on Feb 19, 2010
SOURCE: SONY MDRIF610 Wireless infrared headphones -- I
Hi, to reach the internal battery You have to 1) gently detach the L(left) internal soft ear cover from the headphones, 2) Unscrew the 4 internal screws -- To replace the original NiCd 600mAh battery, You have to unsolder the contacts of the old battery and solder the contacts of the new one. You must buy a battery with soldering tabs, because tabs are very hard to solder well. - Yes, ONLY with this model You may use a NiMh battery, because the original charge-circuit was designed to stop after the battery is fully charged. (NOT many NiCd battery chargers have a cut-off circuit based on battery charge. they use only thermic protection cut-off) -- I've used 2800mAh NiMh to solve the problem, but I'm thinking to use the new hybrid cells battery, because they have a very small discharge rate when are not in use. -- No, You must not use LiIon or LiPo because they need a more precise charging rate and they may explode.Simply don't do that! ;-)
cheers, Rcatech
Posted on Mar 02, 2010
How do you get the m100 to take pictures by motion only?
Search Results
    [PDF]Instructions for M100 GameSpy Digital Camera - TrailCamPro
    THANK YOU for your purchase of the M100 GameSpy Digital Camera. Please ... The Mode Button selects the 3 modes of the camera - Camera Setup Photo Review or ...Accepts the Moultrie PowerPanel accessory (sold separately) only. ... Camera operates in Plot Cam mode during the day and Trail Cam Mode during.
    Moultrie Game Spy M-100 IR Mini 6.0 Megapixel Digital ...
    Rating: 4.5 - ‎21 votes
    MOULTRIE Game Spy M-880 Low Glow Infrared Digital Mini Trail Game Camera ' 8 ....You can easily hold this mini IR camera in your palm. ... MFH-DGS-M100 .... Will ittake pictures only on motion detection? ... can get any size you want but don't forgetyou will have a lot of photos to delete. ... A. Will do video clips and stills.
Dec 25, 2015 | Moultrie Game Spy M100 Game Camera
I have a M100 camera and it uses batteries in a day even with my moultrie power panel
Are you sure that power supply is coming fine from that power panel? Otherwise it should not use Battery.
Apr 24, 2014 | Moultrie Game Spy M80 Infrared Digital...
The mode stays lit up but no mode displays
contact moultrie. should know this fix.
Oct 11, 2013 | Moultrie Game Spy M80 Infrared Digital...
Moultrie m80 5.0 camera will enter trail mode and none of the other modes
had to program mine thru setup menu for mode I wanted to use..pressing mode and hold several times works sometimes.
Sep 12, 2011 | Moultrie Game Spy M80 Infrared Digital...
How to download pics to computer from camera. set on cam mode. not sure how to do this. directions are confusing. thanks for any help.
Don't turn cam on...just plug into an USB port and Windows should recognize it and cam goes into USB mode...a pop up should appear with options...use the picviewer option.
Aug 27, 2011 | Moultrie Game Spy M80 Infrared Digital...
I can't find software updates or upgrades for my moultrie I65 game camera. I have looked all over moultries site and can't find them!
The only upgrades Moultrie has is for the D55 and D55IR models...and these only reduce trigger other software updates available yet.
May 10, 2011 | Moultrie Feeders Catagory Electronics...
I have a moultrie spy 40 a bear i think pulled it off a tree . It will not turn on now . It has no power.
Been bear ripped 4 cameras off trees and destroyed 3 of 4 feeders...repaired feeders...cameras had to be replaced(in bear-proof cases)...water had gotten SD card had bear's pics.
Aug 06, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
How to change the timing of pictures on the moultrie to not catch everything but deer.
In the setup, it has a function to delay time between pics...1 min. works best for game trails; 5 min. for feeders, ect. However, these cams are sensitive; blades of grass; a bird flying by; the tree it's mounted to swaying; heavy rain...should I continue?
Nov 08, 2009 | Moultrie MFH-DGS-100 Digital Camera
Cameras Logo
91 people viewed this question
Top Moultrie Cameras Experts
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
