Cars & Trucks Logo
A
Anonymous Posted on Feb 28, 2015
2002 intrepid engine surge at 4000 rpm at neytral and park.?
Car engine surge when engine speed increase to 4000 rpm at neutral and park.
gbob59
Level 3:
  • Cars & Trucks Master 3,063 Answers
  • Posted on Feb 28, 2015
gbob59
Level 3:
Answers
3063
Questions
Helped
705716
Points
10419
Be careful, could be dangerous, and similar to the Toyota problems before. Gas pedal and or linkage sticking? Last time serviced?
2002 tacoma neutral safety switch code 1780
problem areas include park/neutral safety switch, the circuit for the switch or the ECM. code appears when either the ECM detects
2 or more switches are ON simultaneously for R, N, 2 and L
positions. Or
When driving under conditions (a) and (b) for 30 seconds or
more, the park/neutral position switch is ON (N position).
(2 trip detection logic)
(a) Vehicle speed: 70 km/h (44 mph) or more
(b) Engine speed: 1,500 ? 2,500 rpm
1helpful
At 4000 rpm the engine skips, what could be the problem?
Basic tune up is good place to start and may increase fuel mileage as well.
What is the ignition timing for 2002 nissan hardbody 2000i 16v
Here are the 3 engines listed for this year. IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 2.4L SFI 4cyl
The Ignition Timing
18-22 DegreesBefore top dead center - When throttle positionsensor disconnected and using suitably programmedscan tool.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (750-850 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (700-800 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI SC 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chockdrive wheels, curb idle speed (700-800 RPM)transmission in neutral.
Car surging
Is the car equipped with the Automatic Transmission?
If so, read on.
Otherwise skip to the end and answer some questions.
POSSIBLE SCENARIO:
I have observed a condition where my car surges slightly when the torque-converter clutch (TCC) cycles between lock and unlock when driving on an uphill grade.
First some basics and history that will explain why the TCC is used.
Engine, Torque Converter, TCC, and Transmission relationship--
The TCC allows for a solid connection between the engine and transmission which allows the input to the transmission to rotate at the same speed as the engine.
Without a TCC, there is slippage between the engine and automatic transmission. The slippage is greatest at low engine RPM. That is what allows the engine to run with the automatic transmission in gear, like when you first shift into gear or stop at a stop sign. When the throttle pedal is depressed, the engine RPM begins to increase and the torque converter begins to slip less and less the more the engine RPM increases. The car moves. But even at cruising speeds the torque converter slips slightly. Engine RPM is greater than transmission input RPM, which is realized as slight decrease in fuel efficiency.
When acceleration is complete and a constant speed is being maintained, the engine power output is reduced to the point where the TCC can engage and eliminate any slippage between the engine and transmission. If the car has a tachometer the engagement of the TCC can be verified when a slight reduction in engine RPM observed without a corresponding change in vehicle speed.
One method used to test the operation of the TCC is as follows:
Find a flat section of road where it is safe to perform the test.
Reach a steady speed and keep the gas pedal depressed with one foot. While observing the tachometer (or listening for an increase in engine RPM), with the other foot depress the brake pedal enough to activate the break light switch but not enough to engage the brakes. When the brake light switch activates, the TCC receives a signal to disengage. With the gas pedal being held steady, release the brake pedal and the engine RPM should decrease when the TCC engages.
Old cars with Automatic Transmissions did not use a TCC. I believe the TCC was put in use in an attempt to increase fuel economy.
MY EXPERIENCE WITH SIMILAR SYMPTOMS
The condition that causes that issue on my car is this:
- A slight uphill grade increases the load on the engine.
The car tends to gradually slow and it is necessary to depress the gas pedal to maintain speed.
- Depressing the throttle pedal (manually, or automatically with cruise control engaged) signals the torque converter clutch to unlock when the load increases slightly. (A more drastic load increase would signal the Transmission to downshift to a lower gear.) The corresponding increase in engine RPM and output is enough to compensate for the reduction in speed. When the vehicle speed, engine RPM, and throttle position stabilize to the point that the TCC will engage and the engine RPM will reduce in correspondence with TCC engagement. Now, if the road conditions have not changed, power output is not enough to maintain vehicle speed. With the increased load caused by full engagement between engine and transmission, and the cycle (surging) repeats itself until the road conditions change.
Does that help?
If not:
QUESTIONS
Please define the symptoms.
What are the road conditions when the surge occurs? (A slight uphill grade?)
What is the frequency of the surge?
Does the engine power output have a noticeable surge?
Is there a speed change related to the surge?
Does the tachometer move up and down with little or no change in vehicle speed?
Are all instrument indication in the normal range?
What else has changed?
Transmission trouble?
is rpm at 4 means rpm at 4000. if so assuming everything is okey in the transmission. check your Vehicle Speed Sensor it looks like your not getting the signal which tells you computer to shift at overdrive when speed is over 50mph.
1helpful
Engine surges under load at 3800 rpm
yes it could be. have fuel pump pressure tested, fuel pump pressure should be. (key on engine off) 1999 to 2000--with egr--41 to 47 psi without egr--52 to 58 psi,
Engine surges under load and not under load
Surging is often caused by a bad sensor in the air/fuel supply - MAP, IAC or TPS. Check for trouble codes (DTCs) using a good code reader.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
