Question about Procom (177653) Utility Heater
Pilot Orifice plugged
Dirt Dauber found its way into the pilot light assembly this summer. I have cleaned the barrel but the orifice is plugged and will not come clean. Where can I find a new orifice. It screws out not much to replace just to locate.
  • 625 Answers
Take the thing out and soak it in water. this will break down the mud the wasp uses to make its nest. then blow the thing out with compressed air.
Posted on Nov 15, 2007
How to clean pilot orifice
DEPENDING OF THE ACTUAL PILOT ORIFICE YOUR REFFERING TO, ITS ALMOST ALWAYS BEST TO REPLACE IT ENTERILY. Theyre is always the problem of you increasing the orifice size by merely cleaning it. When i do clean it, i usualy use a solution especialy made for this, althought u may use soap and water and/or varsol;/ It all depends what the dirt if formed by
Oct 10, 2016 | Heating & Cooling
Pilot light lights but is a low flame
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
Jul 03, 2014 | Frymaster Dean Kitchen Appliances - Others
When I try to light the pilot, the flame light at the small hole on the outside on the pilot burner
You have a plugged pilot orifice. That small hole is basically an air intake for pilot when working properly, and when it gets a spider web or something in it, the pilot flame will burn rich (orange/yellow). When pilot orifice is plugged, that"s the next closest place for propane to escape, thus, flame . You need to either blow compressed air in to pilot tube end where flame is normally at, and hope it cleans debris out, or use a 3/8 and 5/16 wrench and disconnect pilot tube from end and remove orifice in pilot assy, and make sure small pinhole is cleared in center of orifice. Be careful when removing tube, as it is aluminum and can crack very easily, especially if older. The best thing to do would be to stop at RV store and get a new pilot tube and thermocouple assy, and install new. Not very expensive, and troubles should be over for years to come with regular servicing. New assy, comes with new orifice etc.
Sep 13, 2012 | RTO Atwood Water Heater - 6 Gal LP
The pilot light takes a long time to light, once lit it barely has but a small blue flame, what is the problem?
Ensure that the unit receives the standard gas pressure as rated on its nameplate.
Pilot orifice may be partially plugged or has some dirt on it, You have to dismantle the whole pilot assembly to gain access in cleaning the pilot orifice. Be careful not to enlarge the orifice bore in cleaning for that will only result to poor pilot flame quality.
The thermopile must be free of soot or soot form of dirt in order to detect the right amount of heat from the pilot flame so that it could also, in turn generate the right amount of voltage needed by the gas valve for pilot and burner operation.
Jun 23, 2011 | Vulcan EF3 Deep Fryer
Thanks, so how do I clean the pilot orifice ?
You have to remove the pilot assembly in order to clean the pilot orifice, make sure to shut down the unit before doing this.
Unscrew the pilot assembly from the pilot holder, dismantle the pilot assembly from the pilot flexible tube using a vise grip and an adjustable wrench,.Remove the pilot orifice from the pilot head and clean it with damp cloth, you can clean the orifice hole using a smallest pin you can find, make sure that the hole will not be damaged or enlarge once you do this, otherwise, pilot flame quality will become poor and will produce soot.
Apr 08, 2011 | Pitco Frialator 40CNG Deep Fryer
Have problem with w355 f cozy wall heater won't turn on with pilot light working. Sometimes if I bang on the valves control it will lite up.
need to clean out pilot orifice, unscrew the silver tubing from the pilot and a 1 inch long orifice will fall out, clean by either blowing air or a clean out bit, if there is just a small amount of dirt or debris that comes from the gas this will reduce the amount of voltage to the valve.
Dec 27, 2010 | Cozy (W352E) Heater
Can not get pilot to lite was working fine had to turn off gas will I changed out some water pipe went to relite and could not get pilot to lite
I would first make absolutly sure that I had all air bleed out of gas line to water heater. If you are trying to bleed air out thru pilot assembly this can take a long time because the opening in pilot orifice is very small. To speed up process if you have a union close to unit or flex connector,you can slightly loosen fitting till you can hear a little hiss of escaping air/gas. When you first smell gas immedieatly tighten fitting. Before you do this make sure there are no standing piloy lights or other sources of flame in the vicinity. When you smell gas and tighten fitting back up try to relight pilot to water heater.If you still can't get pilot to light I would remove pilot line from gas valve and burner. Check to see if you can blow thru it, visually inspect pilot orifice, and if blocked I would get a orifice cleaning tool from hardware or welding supply store. Be careful to select the right size for your orifice and clean it. Reinstall and try to light pilot again.Hope this helps. Thanks
Nov 17, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot goes out after heat cycle, relight and it stays burning untill next heat cyle has run.
This sounds like a dirty pilot jet orifice or a weak thermocouple. The pilot orifice can carbon up (natural gas is a fossil fuel), become weak and keep going out whenever the main burner lights, which causes a pressure drop in the gas line. The thermocouple can also become dirty and not sense properly.
The pilot light assembly should be cleaned. The gas must be turned off and it's best if the pilot assembly can be removed. Automotive carb cleaner can be used to clean the orifice. Do not try to insert any object into the pilot orifice valve as this can result in damage.
If cleaning does not resolve the problem, replace the thermocouple first. Make sure it is installed correctly and is squarely in the pilot flame.
Dec 10, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light will not stay lit on model 465FX-R wall mounted gas furnace. Thermocouple was replaced but still won't stay lit. Gas is on at the meter. Any suggestions?
It is possible that gas valve is bad, however, try replacing the pilot orifice located in the pilot assembly. If the flame is inadequate it will not generate the voltage required in the thermocouple. Pilot orifices are less than $10 and can be found at your local heating contractor's parts counter. Bring in the orifice to match.
Oct 03, 2009 | Heating & Cooling
Intermittant flame, ignitor function is good, all other functions are as designed,timer ,tumble etc.
The pilot light flame would sometimes get very small and keep going out. This was usually because the pilot orifice was getting dirty and was partly plugged. The pilot orifice must be cleaned out when the flame becomes too small to light the main burner. You can blow air through the pilot assembly to help clean it out, don't use something metal in the pilot orifice hole or you risk enlarging the pilot gas feed hole and the pilot light may be too BIG. If your pilot flame keeps "going out", chances are you will need to replace the pilot latch do make sure the vent hood flapper is closing ok and no outside air blowing in is effecting the pilot flame.
This is a thermocouple that sensed the heat from the pilot flame and kept a small amount of gas flowing to allow the pilot light to stay lit. If you followed the instructions ( usually found inside the small access door on the front bottom ) on how to re-lite your pilot when it goes out and the flame will not stay on, replace the pilot latch assembly.
Please accept the solution and revert for further assistance.
Jul 07, 2009 | Whirlpool GGQ8831L Gas Dryer
Procom (177653) Utility Heater Logo
228 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
