Same as other guy, blinking timer light and unit won't power on. Does not respond to anything except the power button(on the unit and the remote) after about 10-15 seconds when initially plugged in. Hear a clicking sound and there seems to be a discharge of electricity and the timer light goes out. After about 3 seconds and the light comes back on. Waiting another 10-15 seconds and you can repeat.
Replaced the fuse but that wasn't the issue. Also let it sit unplugged and plugged for respective 24 hour periods but no change.
I inserted a dvd into the player. It closed normally but sounded like something was stuck to the...
(More)
I inserted a dvd into the player. It closed normally but sounded like something was stuck to the disk-- like part of the adhesive dot that held the disk inside the plastic case.
Hi , I have a pioneer DV 285. While watching a movie the screen on my tv went blank, I looked at the...
(More)
Hi , I have a pioneer DV 285. While watching a movie the screen on my tv went blank, I looked at the dvd player and saw that there was no power on the dvd player, after searching a bit I found that I was sitting on the remote. I turned the power back on and the dvd player says it's loading for about 15 sec then the power goes off automatically. If I remove the disk the power always stays on but as soon as you put a disk into the dvd pkayer it powers down after 15 sec. Does anyone have any idea's ? Thanks Steve
Hi! My Pioneer DV-185 has spontaneously decided that I require closed captions, and I can't take...
(More)
Hi! My Pioneer DV-185 has spontaneously decided that I require closed captions, and I can't take them off. I also can't hear any sounds at all. No matter what I do to the settings, it won't go back to sound. It was working fine only five minutes before (I had to turn it off to answer the phone). Help, please?
Comment fait-on pour d?zoner ce type de DVD? Quel est le code et la proc?dure ? suivre ? Merci ?...
(More)
Comment fait-on pour d?zoner ce type de DVD? Quel est le code et la proc?dure ? suivre ? Merci ? tous How to uncode the Pioneer DV-285 S ? What is the code and what are the procedures ? Thank you all
