Question about Hitachi 53FDX01B 53" Rear Projection Television
Hatachi 53FDX01B We have the above modle and when we turned set on today the picture is dark. Have turned the brightness and contrast to max but it is still dark. what is going on here. i have done a convergence adj. and all seems to be fine there.
  • flyrod40 Dec 23, 2007
    I am having the same problem, can anyone help?
  • 58 Answers
The screen drive or filament voltage is low
increase the the screen drive first.
mounted on the flyback transformer.
guy9
Posted on Jun 10, 2008
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
Tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Mar 06, 2010 | Televison & Video
Picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
Aug 19, 2009 | JVC AV-27530 27" TV
Picture is very dim
there is a problem in the flyback section of the tv set. the fly back has two knobs, one for screen and the other for focus. use the screen knob to adjust the brighness. if it did not help, either check the capacitors around the flyback or change the fly back with a new one. good luck
Jun 01, 2008 | Televison & Video
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Hitachi 53FDX01B 53" Rear Projection Television Logo
144 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
