The switching software that you installed on your computer when you installed the KVM includes an optional setting called "scan" that can be set to automatically page between the two displays.
This is most often used when the device is used for network or server status monitoring. If you configured that to switch every one second I can see how that would be very annoying.
Check the configuration of the switching software to verify that the scan setting is turned off.
Same problem but with a cheap kvm.It does not recognize the mouse until you unplug then plug it back...
(More)
Same problem but with a cheap kvm.It does not recognize the mouse until you unplug then plug it back in.Ater that it is fine to work and to switch computers.
Flip Switch is not lighting up on Belkin Switch2 2-Port DVI KVM (F1DG102D) with remote even with...
(More)
Flip Switch is not lighting up on Belkin Switch2 2-Port DVI KVM (F1DG102D) with remote even with power supply on.
I have new computer and KVM switch works (scroll lock) from new computer to old one. When I try to...
(More)
I have new computer and KVM switch works (scroll lock) from new computer to old one. When I try to change back to new one nothing happens. I have try with other KVM switch and also change connections but... ??
The monitor resolution is lower when docked laptop hooked on via the KVM switch. ControlPanel's...
(More)
The monitor resolution is lower when docked laptop hooked on via the KVM switch. ControlPanel's Display shows max resolution which is still lower than when laptop connected to monitor directly. How to go about this issue? Thanks, A
