Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Freezer stored on its side
I know you are not supposed to store a freezer on its side, but it happened. Of course now the freezer will not freeze. Is there any solution?
  • russ63 Nov 13, 2007
    Thank you and... I was afraid of that. I have had the freezer upright for much longer than 48 hours. The fan and compressor are in fact both running. I know that oil from the compressor can get into the wrong places if it has been on it's side for very long and it was on it's side for over a week. Looks like I'll be freezer shopping.
  • 290 Answers
There is always a solution, some are just more expensive than others.
First you need to figure out if the problem has to do with the refrigerant system or something else.
You want to verify the compressor is running. You can tell this by listening to it or placing your hand on it.
Make sure the fan inside the freezer is running. It is common for the fan motor to stick when not in use due to moisture in the cabinet. You can usually get it started with your finger and it will be ok after it runs a while.
If the fan and compressor are running but it won't get cold, you probably have oil in the lines from it being on it's side.
Turn the freezer off and let it sit for a minimum of 48 hrs.
If it won't cool after that, you will have to have a refrigeration tech out to check the system. You can probably buy a new freezer as cheap as having the system repaired.
Post back and let me know what you find out.
Posted on Nov 13, 2007
  • Michael  Lindley
    Michael Lindley Nov 13, 2007
    If you ever have to put a freezer or fridge on it's side again, look at the lines coming from the compressor. If both of them are on the same side of the compressor, lay the unit over so that they are sticking up. If they come off each side, lay it so that the discharge line is up. It is usually the smaller of the two.
    Sorry I couldn't be of more help.
My chefmate freezer stopped freezing
have you looked as for a hole or opening and if there is none then this has happened to me you could take to the the store you got it at or get a new one but if there is a hole you could use a "freezer glue"
Jun 25, 2012 | Magic Chef Freezers
Hello i have a kenmore chest freezer model 25519702010
It sound like either the compressor is damaged or the system has a leak. Either way if it's only 6 months old you should call the store you bought it from and have them book an appointment to have it repaired under warranty. If it's not under warranty then you'll still have to have a tech check it out with special equipment that you won't find in any store.
Dec 20, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
Apr 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
FREEZER NOT FREEZING AND F RIDGE FEELING WARM
Before you throw out this refrigerator, try a few simple tests.
First, open the freezer while the compressor is running and listen for the fan running. If it is not, this could be your problem. Replacement fans can be ordered from on-line parts stores, a local appliance repair shop, even ebay.
Second, try turning off the refrigerator and letting the coils in the freezer thaw completely. Of course, move your food to a safe place for a few hours while you thaw the freezer. If you really get ambitious, remove the rear panel from the freezer and look to see if the coils are frozen. If they are, thaw them and dry the freezer compartment completely. Reassemble the freezer and restart the refrigerator.
If the problem reoccurs, you may have a problem with your defrosting circuit.
Jan 30, 2010 | Frigidaire Freezers
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Bread gets ice inside the bags,bread hard when thawed in places cannot use for sandwiches so i am throwing it out.The freezer was my Sisters so i use it as an extra to the chest one i have. Does this...
Sounds to me like it is taking the freezer to long to actually freeze the bread, and therefore the ice formation. It could be due to a dirty coil, a bad seal, or like you mentioned an old unit. I would clean the coils and ensure proper door alignment. If this does not help, but you would like to continue using the freezer, make sure to put anything you are going to store into the refrigerator first, or pre-freeze in you other unit. Hope this helps
Sep 22, 2009 | Freezers
My freezer is supposed to be at 0 degrees and its at 14. Its only about 3 years old. Its a GE side by side. Do you have any suggestions on what I can check?
Take all your things out of the freezer and pull the racks out. there should be a way to remove the back panel inside. Behind the panel is a bunch of coils. If they are covered in ice you have a problem. At the bottom is usually a single element or double element heater. Replace that and you should be good to go. They are about 30-40 dollars at your appliance store. They will need your model number to get the right one. Let me know if that works.
Sep 19, 2009 | GE Freezers
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Freezer motor works fine, but doesn't freeze.
  1. you probably have oil in your line.you're not suppose to plug the freezer right a way when it have been loaded on is side.you suppose to wait about 24 hours.
Jan 28, 2009 | Carrier 20.7 cu. ft. Freezer Beverage-Air...
Meat freezer burns
Hi,tomonbow
ngafm at your service,
You said,you are getting freezer burn in only two days, right?
Are you putting the meat in proper freezer bags and squeezing
air out as you zip lock the bag?
If you do not use proper freezer bags you will always get freezer burn on meats!
WAIT ! This will not happen in two days!
Seems to me something else has happened to your meat prior to your purchase and it probably is not the freezer at fault.
If it happens to meat that you feel was not frozen when you bought it, check with the store of purchase to see if it came into them frozen before it was put in their refrigerator case!
Most super markets receive cases of frozen meat and then put them in the walk in refrigerator, or refrigerator case to present them for sale to the customers and they defrost in the case.
Then we think we are buying meat that is fresh and never been frozen!
Fresh meat will not freezer burn in 2 days unless it has happened previously to the time you bought it.
Also when you freeze any meat you buy, repack it in proper freezer bags and not just any zip lock bag!
But I believe it happened before you bought it.
And i'll bet it all came from the same store.
that's why some people shop at a butcher shop or Costco type store where the meat is fresher and sells out faster!
Bless you.
ngafm
Please give me a good rating before you sign off.
Thank You.
Let me know the verdict. I think I'm right on target!
Do some investigating and ask the store some hard questions!
Sep 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
204 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
