Question about Hitachi 46W500 46 in. TV/DVD Combo
Prob on the screen the characters are shadowing or ghosting almost looking 3D like i cant fix it
    Scholar:
  • 133 Answers
Covergence problems . Could be loose contacts on the output IC's or bad IC's . If they are bad they generally also have bad resistors or fuses that open up as well .
Posted on Feb 28, 2008
How do I fix double printing
Not sure what you mean by double printing.
Is it printing a ghost of what you print further down the page. Or is it mis-aligning the characters so it appears to have a shadow on each character?
Aug 11, 2014 | Brother MFC-465CN InkJet Printer
My Lg colour tv is getting these weird red and blue shadows that makes the picture looks like it's in 3d can I fix this?
thats called ghosting its usually down to your tv ariel try putting your ariel on a mast for a better clear reception.
May 05, 2014 | Televison & Video
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
3D image, ghost image, with shadows. how can I fix it?
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 05, 2010 | Sony KP-46WT500 46" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
Green shadowing
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Hitachi 46W500 46 in. TV/DVD Combo Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
