Question about Toshiba Satellite A105 Notebook
Safe mode has a partician
I want to format C drive and add specific items to it
  • 38 Answers
Re: Safe mode has a partician
Please first specify what specific items are to be added
Posted on Dec 05, 2007
0 characters
3 Points
HP Pavilion dv6-2190us screen blank, all lights on. No worky. Any suggestions?
Based on your description, it is recommended that you refer to the following information:
You can start (or restart) HP (COMPAQ) appears, stop clicking F8 keys the view safe mode is normal.
1 If safe mode normal, you can turn to test the following method:
1) Device Manager to roll back the driver or reinstall the driver test.
2) the new account in safe mode and test disable startup items (click on the lower left hand corner of the keyboard and the Windows logo key R calling Run, type msconfig command, go to "Start" to remove unwanted boot automatically start the program in front of the check mark ).
3) backup data, reinstall the system.
2 If safe mode is not working properly, you can try to save important files after format hard drive to reinstall the operating system under to see if you can solve the problems you encounter.
Reply to help you more than friends, I hope
If you need to work from a trusted retailer of batteries, you know, you do not wrong by choosing or Because the products we offer absolutely cheap, high-quality, 100% safe, 100% compatible, 100% satisfaction.
Mar 15, 2013 | PC Laptops
The computer crashed, and i would like to see if there is anyway i can restore it. it wont even work in safe mode
If your notebook has a cd or dvd drive you can put the operating system disk in it and restart the pc and try to boot from the disk to restore it. If you dont have a drive, then find out where the maker installed your recovery hardware and boot from there. Most either include it on a an additional drive partician or sometimes you can download it to a pen drive that you insert in a usb port and restore your system using that method.
Aug 17, 2011 | Sylvania G-Netbook
My laptop get restart in an intervals or get hang ...
This will occur if the Windows files are Corrupted or Fragmented, the solution is to backup by logging in to Safe Mode. Please restart the computer and try pressing F8 Key to select Safe Mode. If the Safe Mode is working fine then please backup the data and Format the computer using the Window XP or the Operating System Disc which you have. If the Safe Mode is not working then use any Linux CD like Ubuntu ( it's free! Then boot the CD to backup the data for any external Hard Drive or Pen Drive and format the Notebook using the appropriate Operating System Disc like Windows XP, Vista, or Windows 7.
Mar 26, 2011 | Toshiba Satellite Pro L300 Notebook
I got win 7 installed on C:\ drive second
Hidden partition is created during the Windows 7 installation it is about 100Mb
Apr 29, 2010 | Acer Aspire One AOD250-1924 Netbook
I reciently installed a bigger HD and now I get the"blue screen from hell"!! How can I get it to boot on the new HD?,Ray
did you format the hard drive first?
typically you need to format the hard drive using the NTFS file system before you install your operating system.
does your bios recognize the hard drive?
make sure your bios detects the hard drive.
can you boot your computer in Safe Mode? If so, do that and use your error log to find the specific cause of the blue screen,
lastly post the blue screen error message on here to get a better answer.
Nov 26, 2009 | HP EliteBook 6930p Notebook
-Was using the laptop toshiba A40 for several hours -The computer shut off on it?s own -Upon restart the computer goes to a prompt screen asking you to choose to boot from one of the following: Safe Mode,...
it is a bad hard drive, 12 hours is too long its a slow drive therfore you just need a new hard drive (new not used from ebay) and format xp and bob is your uncle. dont think that i will try other stuff to still not spend to get a new hard drvie but it is time you cof'up lol good luck
trust me i know
Jul 30, 2009 | Toshiba Satellite L305-S5907 Laptop
My dell inspiron is not working
its not a big problem,first don't panic.just follow the steps i m telling you-
when computer give options like safe mode,safe mode with net working etc.enter on safe mode
after that if windows starts thn run your antivirus installed in your computer and if u dont hav antivirus then install it using pendrive or cd and run it.
after full scan od the system restart computer again.
if problem persists then again start your computer in safe mode and cut all the importand data from your c drive and paste it on d drive or e drive and reinstall XP or VISTA but remember while installing XP OR VISTA computer will ask you to format whole computer or the c drive only,u only format c drive.
tht's it
and always have one good antivirus installed in your system and update it regularly.
Jul 14, 2009 | Dell Inspiron 1501 Notebook
How to format a Toshiba M100
get a win 98 boot disk floppy. set bios to read floppy or usb floppy first save and exit. insert disk and boot comp. select boot without cd rom support. At command prompt type " FDISK " then hit enter dont type quotes. delete the particians then create new partician set 1 particians as active then remove disk then insert OS disk and go forth. I after you install your new OS and you get two boot options at the command promt after loading type " delpart " and delete the particians and save (use the tab and alt keys to bring up menus save and exit before you leave delpart) reboot and run fdisk to creat a partician and set it as active. then load your OS
Jun 10, 2009 | Toshiba Satellite M100 Notebook
Can get the aspire to boot to windows
try F8, that's usually safe mode. press it like once a second as it's booting.
what's your specific problem-- cant boot windows?
can you try putting a windows install disk in and choosing "repair" when it boots? (you want to make sure you dont format your drive though, repair wont do that usually if youre careful)
Feb 02, 2009 | Acer Aspire 5100 Notebook
If you really can't access the recovery section and you really want to format your PC, then put on the Vista CD and reboot. Boot using the Vista CD and paritition or format your hard drive then install the O.S. etc.
Aug 26, 2008 | HP Compaq Presario V6000T Notebook
Toshiba Satellite A105 Notebook Logo
24 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
