Mr. Coffee 12-Cup Programmable Coffeemaker Logo
A
Anonymous Posted on Feb 27, 2015
Slow dripping and ground cup is extremely hot
Cant get a cup quick enough
Sheridan Swafford
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 16, 2015
Sheridan Swafford
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
993
Points
18
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Why is there coffee on the burner, after coffee brews?
The flow control valve on the strainer basket (where the coffee pours into the pot) is a less-than-stellar device. While adequate to prevent a flow of coffee when you pull out the pot, it will still retain a few drops which slowly drip onto the warming plate while you are pouring a cup. It may even allow a slow, continuous drip, especially if coffee grounds find their way past the filter.
Keep a damp cloth or paper towel near the coffeemaker while it is on. Just before returning the pot to the plate, give it a quick wipe.
Keurig drips too slow
The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
How does the drip method work to produce a cup of coffee?
Hot water is poured over ground coffee, which is contained within a filter. The water then steeps and drips through, producing coffee. This method of making coffee is also referred to as filtered coffee.
Coffee grounds in the coffee pot. It appears water does not flow into pot quickly enough, so filter basket overfills and causes grounds to go up and over the filter, then flow into pot. Also heat plate...
From what you described, it sounds like your carafe isn't fitting properly. The lid of the carafe is supposed to open a valve on the bottom of the filter basket. If this valve is clogged or not opening completely, that will produce your symptoms. Also, the warming element will not keep carafe hot if the carafe isn't sitting properly.
4helpful
My Saeco Vienna at times seems to extract a cup of coffee extremely slowly (drips out). The next cup will come out at a normal rate. I've tried the grind at various settings, but the problem remains. Any...
HI You might need new burrs. When the burrs get dull, they will crush the beans instead of grinding them into small grounds. You start to get powder instead of grinds. They will slow the extraction, but then the next time they will produce the correct shot.
7helpful
2answers
1. After brewing a cup of coffee, when the grinds are emptying, a stream of coffee and grinds drains into the Drip Tray from the valve(?) in the rear right of the Drip Tray. We have gone into program mode...
HI
Excess water into the drip tray is an indication that you don't have enough coffee going into the brew unit. There is a lever on the top of the door that has a + on one side and a - to the front. Push the lever back to the full plus, then pull it forward 1 click. Try that.
Water into the drip tray is normal in small amounts. This is the release of pressure after brewing, like the 3 way valve on commercial machines
Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Very slow water output
Open door of machine & take Brew head out. You will see a cylinder shaped part which is black with an orange washer half-way down it. Look underneath this cylinder and you will see a steel disk,(which may look black) this is the filtre. Now look above the cylinder and you will see a turn knob, turn anti-clockwise untill the disk comes free. Hold the disk up to the light and you will see the minute perferations which are all clogged with coffee grounds, give this a thorough washing under running hot water ,( use the brush provided with your machine to push the grounds through. You will also need to blow through these holes very hard and often untill you can see that they are cleared. This should be done after about every 15 cups made. I got this info. from the Gaggia engineer and it works!! Good luck.
1helpful
2answers
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
