On screen it says an unexpected I/O error has occurred, just a black screen no mouse working nothing it also has file\boot\bcd on screen and also status:0x00000e9 thanks for any help
this is a hardware issue, you may need to boot on safe mode and update most of the drivers installed, run windows updates too.this is a hardware issue, you may need to boot on safe mode and update most of the drivers installed, run windows updates too.
You can't post conmments that contain an email address.
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop.
The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file.
You can try the following steps and can try to resolve this issue:
1. Boot into the Windows Recovery Environment (WinRE)
2. Launch the Command Prompt.
3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd".
4. Press Enter and follow the on-screen instructions.
Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
If you have backup disks with your data on and a recovery disk, now is the time to use it, otherwise, press F8 as it boots and select Safe Mode. Run CHKDSK/F and hope that it can repair the errors. If it does, close the computer down and re boot as normal. Hope that helps.
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
