Where did you get new antenna? If no instructions talk to the Autoparts store where you bought it. There should be instructions with the antenna. What happened to old antenna? A motorized antenna? If motorized, antenna has a white nylon gear tooth at back end. If it's not motorized it may not match. The bezel usually screws into the motorized device underneath the body work. Should be way to use small wrench to turn just like a nut to remove. Hope this helps. I've changed mine several times, by going throug the carwash without turning off the radio, but
different car.
SOURCE: 1997 toyota 4-runner. the antenna
http://www.carstereohelp.com/stereoremovalToy4Runr2PwrAnt.htm
SOURCE: radio antenna mast replacement
ON AN ELECTRIC ANTENNA, YOU CANNOT JUST REPLACE JUST THE MAST.
SOURCE: Electric Radio Antenna on 1994 Toyota Celica
Reverse the wires, one is hot going up and the other hot going down, the easiest way to deal with this is to just reverse them.
SOURCE: Antenna mast broken
Give these instructions a shot. Might be too generic but might be enough to get you going.
Removing Original Antenna
Installing the New Power Antenna
SOURCE: problem removing broken antenna mast
you have to pull out the trunk interior trim panels on the left side to access it.
there will a few 10mm bolts and a connector.
