It takes several minutes before a single page gets printed
SOURCE: My laser jet 1020 would not print the test page at all !
Install winxp and buy firm USB cable.
SOURCE: Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
SOURCE: double printing on single jobs.
You have software setting problem Check and double check your print dialogue box
SOURCE: My hp office jet 7210 takes several minutes to
I suspect that you are looking at a flow control issue and not a printer failure.
You can check the printer driver and make sure your printer options for background printing.
Also, make sure that your document is not too busy. I've had customers complain about slow printing documents and when I examined the documents, I discovered that there were multiple images overlay ed. The data still had to be sent, but only the top image printed.
Don
