I cleaned my unit a week ago, removed the plate inside and replaced it with a spare I had. When I put everything back together, the unit run just fine, however, it appears there is a problem with the unit, because I do not get the clean air smell in my house. I am not sure if this is a lack of ionization or another problem and I have no idea if something on the unit needs to be replaced or repaired. Any suggestions would be greatly appreciated.
I have a similar situation. I noticed a "sparking" sound when it was running on high. I went to replace the plate and it broke. I know I need a new plate but there was no smell before this happened. It is probably the same problem as you are having. I do not have a manual so I don't know where to start. I also did something else. I took the filtet off while it was running...then noticed the warning not to do this. Is there a reset on this or will it reset itself? I love the unit and it is the only one so far that has really worked. I hope someone can help with this. Thanks.
-   plates are bad replace BOTH at the same time !!!!!!-   1dean
Nov 17, 2007
-   I have the same problem. I have cleaned unit. The fuse is working the fan is working but the light indicators are not on. so there is no ozone being produced-   Biz1
Make sure you have the filter on the back on the right way and not reversed. On the Ecoquest Breeze you should plainly see the obvious pull tab, at the top of the back filter panel, after putting the filter back in place.
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I...
(More)
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I believe the noise is coming from the (yellow light) fuse-located in the middle right side of the unit. I also noticed the fuse in upper left corner of the unit (which I believe lights up green) is not on -Would the rattling sound be due to the fuse needing to be replaced? Can I replace both fuses myself?
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky...
(More)
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky no ionization is occurring. Fan operates properly, has new plate. No apparent physical issues.
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is...
(More)
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is the problem? the disks are new.
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board...
(More)
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board that is in the left rear of unit. Is this board replacable and if it is where can I get one?
