it goes thru the steps, untill a blue screen with lexmark install
in the middle of the blue screen a window says updating computor
much much time later i turn off machine when i turn it on to use program it says there is no default printer. when i on D drive there it is lexmark 73 118,000mb. ijust got on the internet in july, however the printer goofs up. or the operator did something wrong, added, deleated something. i always thought if i goofed up a could back.step and correct any problem..but i have ventured different things now and not sure what i did. im 65 but im willing to learn, however up here at Mt . St H elens there are not too many 12 year olds around .thanks if you can help . like i said the printer is in great shape it was justsomething i did. Can you help.
Hi, I think maybe the quickest and easiest thing for you to try is to unplug your printer from the computer, turn on your computer and uninstall the software (usually through the "Add/Remove Program" option in the "Control Panel" or "Settings" menu.)
Then restart your computer. If you have the installation guide for your printer then just check whether you have to install the software first before you actually attache the printer. If not then turn off your computer and plug in the printer then restart the system. Windows should find the printer automatically and either install it or ask you for the installation software.
Let the software install and accept all default options as to where it installs to etc.
When it is done restart the computer, hopefully the printer should work ok now. When you go on the Internet if a window pops up and says anything about updating your Printer Driver, just say "No" or "Cancel".
Let us know how you go, and by the way where is Mt St Helens, and keep up the good work.
Was this helpful?
Yes
No
Solution #2
posted on Mar 19, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I lost my cd for lexmark printer now I can't install my printer to my computer and I need this printer because I go to school online and I have to set down and write all my lesson and that a job.
pad is saturated with ink, ink globs in right corner of printer , how do i remove the pad and...
(More)
pad is saturated with ink, ink globs in right corner of printer , how do i remove the pad and disassemble the printer to clean it?
