sounds like a wheel brg, if the noise lessens when you turn to the left while driving more than likely it is coming from the right side, but a brg makes more of a roaring noise.
You should take into a repair shop and have them look at front suspension on your vehicle.Make sure and have a tech drive with you so you can show them the noise it is making.If you just drop the car off and tell them it is making a noise when you turn right or left they could be hearing a different noise.This could cause them repair all sorts of other noises and not fix your problem.There are a few moving parts in the front suspension.That is why it`s important make sure they are hearing the same noise you are.It could be something that is noticed right away or it could be something that you can tell what it is just by hearing it.Hope this helps.Good luck.
It's most likely the left wheel bearing that's causing the noise, when turning to the right the weight of the car shifts to the left placing more load on the left wheel bearing and takes load off the right bearing.
Turning RIGHT puts the heavy load on the LEFT front wheel.
That initially STOPPED the noise, correct? So why did you change L?
Turning LEFT puts the load on the RIGHT. Did you change the RIGHT?
Let's say this:
If turning RIGHT stops the noise, it's the RIGHT one that's likely bad.
If turning LEFT stops the noise, it's the LEFT one that's more likely bad.
Make sense? Turning RIGHT loads the LEFT wheel; and vice-versa as the WEIGHT SHIFTS AWAY FROM THE TURN.
More than likely it is what some folks call a CV joint problem, not wheel bearings. Try backing up and then going forward to see if "clunking sound" or a sharp "bang" is heard. Wheel bearings and CV joints only work if smooth. Sometimes a BEARING RACE is bad. Also, a bad spindle / part of the CV joint / transaxle assembly worn or badly machined. If in a WET ENVIRONMENT especially, u may want to try marine grade grease or teflon-added grease.
when turning left vehicle distributes weight to right front wheel bearing causing load. since u describe a noise in right front while driving straight i would suspect failed right front wheel bearing. see if your noise changes/goes away while turning right that should tell u 4 sure
My advise is when u get a humming noise when banking left or right. Its beter to change both left and right wheel bearing and ball joints. Cause if u think about it those parts are put on at the same time . So if u think about it they have the same where in Terre . left or right hope this helps you.
possibly a wheel beering...to diagnose a wheel beariing, listen closley when making left and right turns...when turning left, weight shifts to front right side, If noise increases, it may be a front right wheel bearing.... vice versa for right turns.
