My cd/dvd is stuck closed and is making a strange noise when I try to eject it. I already removed power and reset but still the same problem.My cd/dvd is stuck closed and is making a strange noise when I try to eject it. I already removed power and reset but still the same problem.
mine will not open either . . . .it always eventually does - a few day later. very annoying!mine will not open either . . . .it always eventually does - a few day later. very annoying!
My Bose 321 GSX CD/DVDV tray won't open. It just says "Opening" or "Closing" but nothing ever happens. Tried the troubleshooting tips in the manual but nothing worked.My Bose 321 GSX CD/DVDV tray won't open. It just says "Opening" or "Closing" but nothing ever happens. Tried the troubleshooting tips in the manual but nothing worked.
AnonymousMay 04, 2008
the cd/dvd tray is stuck in the closed position so I can't get the disc out. What can I do to open it?the cd/dvd tray is stuck in the closed position so I can't get the disc out. What can I do to open it?
321 won't eject CD. Just makes noise as if it were working. More annoying is that nobody can help!!!!!!321 won't eject CD. Just makes noise as if it were working. More annoying is that nobody can help!!!!!!
My bose 321 GSX cd/dvd tray wont open. Just says opening and then shuts off with the message 3.2.1. How can I open the tray??? please help.!My bose 321 GSX cd/dvd tray wont open. Just says opening and then shuts off with the message 3.2.1. How can I open the tray??? please help.!
My young daughter apparently put a sheet of paper into the tray. It won't open anymore. If I could just access inside the bose 321, I think I would be able to get the sheet out. Please help Thank you very much
my 321 dvd player played a new dvd but will not eject it. It makes a whirring sound and then shuts off.my 321 dvd player played a new dvd but will not eject it. It makes a whirring sound and then shuts off.
my Bose 321 has a dvd in the tray put will not eject. It will not allow me to put in on the dvd/cd mode......it will turn off .....helpmy Bose 321 has a dvd in the tray put will not eject. It will not allow me to put in on the dvd/cd mode......it will turn off .....help
bose 321 cd try stuck...making noisebose 321 cd try stuck...making noise
AnonymousSep 09, 2008
I load the DVD in tray and can't play, open or close..I need some help please. ThanksI load the DVD in tray and can't play, open or close..I need some help please. Thanks
I found a dvd with no writing on it . I wanted to know what was on it so I put in the dvd player and now it will not open. on the display window it reads opening then it shuts off.I found a dvd with no writing on it . I wanted to know what was on it so I put in the dvd player and now it will not open. on the display window it reads opening then it shuts off.
same issue dvd tray stuck in closed position and sounds like it is running-no help in Bose manualsame issue dvd tray stuck in closed position and sounds like it is running-no help in Bose manual
I accidently put a blue ray disc in and now will not open. Say's its opening then shuts off.I accidently put a blue ray disc in and now will not open. Say's its opening then shuts off.
AnonymousJan 30, 2009
When I click eject it says opening..... but then it never opens.
DVD open/closed gets lost and becomes inoperable in the closed position. I power down and it resets to fix the problem.DVD open/closed gets lost and becomes inoperable in the closed position. I power down and it resets to fix the problem.
our dvd was skipping took it out to see that there was a smudge on the dvd tried to clean when we put back in would not play or ejectour dvd was skipping took it out to see that there was a smudge on the dvd tried to clean when we put back in would not play or eject
I accidentally insert a DVD upside down, since then I can not eject it and the systems went down each time I try to eject it.I accidentally insert a DVD upside down, since then I can not eject it and the systems went down each time I try to eject it.
AnonymousMar 10, 2009
I accidentally insert a DVD upside down, since then I can not eject it and the systems went down each time I try to eject it. I accidentally insert a DVD upside down, since then I can not eject it and the systems went down each time I try to eject it.
AnonymousJun 04, 2009
Tray is non operatable. Can be pulled out and pushed in manually, but won't respond to remote, and won't play cds or dvds.Tray is non operatable. Can be pulled out and pushed in manually, but won't respond to remote, and won't play cds or dvds.
AnonymousMar 15, 2014
bose 321 remote codebose 321 remote code
AnonymousMar 16, 2014
updat bose 321updat bose 321
AnonymousMar 21, 2014
i turn on bose onit and display lights up instantly , a few seconds later bose 321 appears on screen the screen goes black like it lost power but dvd drive still runnin i can hear spinningi turn on bose onit and display lights up instantly , a few seconds later bose 321 appears on screen the screen goes black like it lost power but dvd drive still runnin i can hear spinning
AnonymousMar 22, 2014
Bose DVD player tray will not open to accept a disk.Bose DVD player tray will not open to accept a disk.
You can't post conmments that contain an email address.
Hello Check its loading belt for borken. you have to open this deivce. an experienced service technician only can open Bose sets. So get this set repaired by any one well experienced with servicing Bose systems. OK.
you can open it up and see if you have broken the ac/dc converter. disc tray could have jammed it up. if you dont know much about them then try calling customer support. ^^
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
To get my unit open I hit on/off and the source button at the same time. Then open showed up on the 3-2-1 window, then I hit the eject button. It works fine now.
My DVD is stuck closed as well on my 321
pulled it out to far and its stuck closed making noise
The dvd tray won't open, the system won't stay "on". I never have been all that impressed with this system. What do you suggest?
Lyn
i have the same problem
Tray says ejecting but only makes a funny whirring sound then shuts off.
ditto.
DVD / CD won't eject.
my bose 3 2 1 GSX closed and will not open it just says opening
DVD drawer makes a clicking sound but won't open.
Who can repair a Bose 321
DVD player won't open even thought it sounds like it will and says it is.
Bose system does not eject dvd in the system.
Please help
Thank you very much
ditto - tray stuck closed.
bose 321 cd/dvd tray stuck closed. Will not open.
My son pulled the front off the drive and now the drive wont open
updat bose 321
