Pioneer A35R 2-Channel Amplifier
Problem for Pioneer A35R 2-Channel Amplifier
Cross wired speakers and blown power transistor.
By pmadden on Jul 08, 2009
Cross wired speakers and blown power transistor. After replacing the blown power transistor, started blowing low power (3A) supply fuses on power up. Where do I look next for problems?
Best Solution
posted on Jul 11, 2009
Helpful)
palaboy
Rank: Wiz  Pioneer Home Audio  Expert
Rating: 82%, 1197 votes
remove again all the new power transistor.
now power up the unit, if fuse still blows, remove the drivers
then measure the voltages if the fuse dont blows again
now check the driver transistors and if bad have it replaced
after powering up, you should have audio out now to your amplifier, test it
if it dont we have to test again backwards
test the unit for a few minutes and feel if there is transistor that is overheating, if the sound is good
you can reconnect good power transistor, better to check first before installing again
a good amplifier does not produce more than 0.7V on its output
hope this helps, thanks for using Fixya!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 09, 2009
Not Rated)
Abrsvcs
Rank: Guru  Pioneer Home Audio  Expert
Rating: 88%, 1833 votes
Often when the outputs get shorted, the "driver" circuit gets smoked as well. If you are having the fuse blow, there are additional semiconductors that are defective as well. This unit should be brought in for service. Realistically, this will need about $30 or so in parts. Without experience, this will be a difficult one to repair.
Dan
Was this helpful?
Yes
No
Popular Solutions for Pioneer A35R 2-Channel
Questions and Unsolved Problems for Pioneer A35R 2-Channel
Do you recommend Pioneer A35R 2-Channel Amplifier?
Answer
Answer
I can't get the 5.1 surround sound to work on my str de475. The blue light doesn't come on to tell... (More)
Answer
rotel 214 just stopped working power light will not come on i have changed fuse in plug.
Answer
The right channel has failed and I am looking for a schematics to facilate the repair
Answer
The stereo just has the over load light lit sometimes and the volume then shuts off. why is this... (More)
Answer
I have a sony 5.1 full digital amplifier with dvd player. when I try to eject the dvd, it displays... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer A35R 2-Channel...:
Top Amplifier and Preamp Experts
Rank: Guru Guru
Solutions: 812
Experience: 30 Years of professional repair and design.
Ask Me
Find more Amplifier and Preamp Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
