If the error code is "LE" then replace the hall/position sensor on the motor, if the error code is "tE" which looks a lot like LE at a causal glance then replace the thermistor that measures the water temp located on the bottom of the outer drum in front.
These codes indicate an over temperature condition. The F2 & F3 error codes both mention the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
Recommend that you closely check the water temp of incoming water. There is an error in some service manuals and if the inlet water temp is greater than 149 degrees (F) (some manuals incorrectly say 194 degrees), you could get an imediate tE error.
If that does not solve the problem:
_recheck_ the electric resistance of Thermistor.
(11~14k Ohms at 77 degrees (F) )
Good Luck!
Trouble Code 33 and 34 are the MAF/MAP Sensor
Circuit. It sounds like you've replaced that sensor already. Did you also have the code 34 before putting in the new sensor?
Or did this code start after it's replacement? Any other codes appearing?
Troubleshooting it would depend if it has the Speed Density
Update. The dealer should be able to provide that info.
