Question about Kitchen Ranges
Oven will not turn off.
I have a Kenmore ready and warm range electric. I was using it set at 350 and it started making a beeping noise and F1 was showing on the read out. I pressed cancel/off but the oven would not turn off. It just kept getting hotter. I unpluged the unit from the power source and I am letting it cool, but I don't know what F1 means. Please Help
  • 1 more comment
  • ladyroadstar Nov 21, 2007
    I have similar problem. My broiler was not working yesterday and today I turned heat to 450 when cooking then the broiler came on and now will not turn off. I had to turn breaker off. I waited for it to cool down, then went turned breaker back on. Although the panel says nothing is on, the broiler came back on again. I didn't get the codes when all of this happened.
  • bjdrennan Nov 22, 2007
    We had the same problem today (thanksgiving day). We put the Turkey in the oven and after about 30 min it smelt like something was burning. I opened the door and the top burner was on and glowing red. We tried to turn off the oven but it did not shut down. (Not Good design for safety.) I had to turn it off by turning off the breaker. Kenmore service sucks! We also have had a problem 1 yr and 5 days after we bought this piece of crap. They would of charge us about $400. for the repair but we had the extended warranty. Now the warranty is out and don't know what it will cost to fix this problem. I am able to fix it myself but yet don't know what component is bad. If it cost to much I may take the range out to the field and blow it up and put it on YouTube to show people not to buy Sears Crap. Wish I could do the same with there crappy service department. Any comments you can email me at bjdutah@yahoo.com
  • yeldems Sep 06, 2008
    I have a Kenmore 92022 electric range with the same problem these people are having. One day I came home to find my broiler element on and I can't shut it off. I have to flip the circuit breaker to stop it. Can I repair this with a new EOC board too?
Kenmore 95002 is the model I have
Posted on Nov 21, 2007
  • 473 Answers
Sounds like an oven control problem. Give me the complete model # from the sticker on the range so I can look into this for you.
Posted on Nov 13, 2007
I have kenmore electric rang oven make beep noise
your main control board has shorted out you can call or go online to marcone appliance parts or allbrands appliance parts and both companies will ship the part directly to your door think there open till 1-2 on saturday also hope this helps
Jul 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
F1 Appears on Kenmore Electric Range
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 23, 2009 | Kenmore 90154 / 90152 Electric Kitchen...
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Aug 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Oven can not heat
f1 is the code for a faulty oven control or as you know it the clock replace it
Feb 12, 2009 | Kenmore 96532 / 96534 / 96539 Electric...
What does the message F1 mean on my Kenmore range?
This probably means the electronic control board has failed. Can you find another model number on the unit? It may be on a metal plate inside the door. This way I can be sure that I'm looking at the correct fault code table.
Jan 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Not a 965 problem but a 956 problem...
shogan, Most likely, the problem is with the circuit breaker. It became too weak for regular load. Replace the circuit breaker and I believe it will solve the problem. Gendos....post back
Jan 05, 2007 | Kenmore 96532 / 96534 / 96539 Electric...
Kitchen Ranges Logo
270 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
