Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have a ge side by side profile refrigerator and can't get the glass shelves out.
Profile at top
  • Jerry Smith Mar 07, 2015
    On the right side of each glass shelf is a plastic tab about half way back. Push down on the tab as you pull shelf forward.
SOURCE:
cactus bob
  • 267 Answers
SOURCE: Need your opinion on buying a new GE Profile refrigerator.
no dont do it GE is just bad news . if you must by ge make suer you buy the extended warr .and keep it current YOU WILL NEED IT ! ....... what one should buy? it does not matter , there all the same refrig inside ,just just STYLE you pick DONT FORGET EXTENDED SERVICE PLAN !
Posted on Jan 16, 2009
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
  • 531 Answers
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Posted on Apr 01, 2009
  • 531 Answers
SOURCE: Refridger Freezes items on shelves and in drawers
check coldcontrol or damper control settings
Posted on Apr 07, 2009
erpaalai
  • 999 Answers
SOURCE: GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Posted on Jun 20, 2009
How do i replace the evaporator fan on myGE Profile PSB48YSXSS refrigerator?
I am not familiar with the "overhead" but the site with VERY GOOD videos and reasonable prices
appliancepartspros.com
... and they offer live assistance... never tried it but it certainly had my 20 year old parts!!
Nov 02, 2015 | GE Profile PSB48YSXSS 48" Built-in Side by...
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
We purchased four new GE Profile appliances in August 2008. I contacted them in October 2009 to advise them that the shelving on the side-by-side of the fridge are to narrow, and the shelving and food...
unfortunately noone can help unless it is a recall and the only way for that to happen is for a bunch of people to complain about the same thing on the same refrigerator and that is a longshot my advice write ge and express ur feelings about the product and sometimes they try to fix the problem but u cant go back to where you bought it they cant help you hope this was helpful
Jan 24, 2010 | GE Profile PSW26P Stainless Steel Side by...
Noisy Fans GE Artica Profile Side by Side
You will have to remove all shelves to access the problem areas. You will sometimes have to look carefully for the screws as they are camoflaged with paint, but i am sure they are there. Hope this helps
Jul 26, 2009 | GE Profile Arctica Stainless Steel Top...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
