Question about Dishwashers
Dishwasher it seems as if i have no power
  • 1 more comment
  • buhddy Jan 30, 2008
    dishwasher went completely dead, no lights, no nothing during cycle. Checked outlet and breaker, all good. Even tried an extension cord to a known good outlet, still nothing. Will check wire nuts at junction box tonight.
    Any thoughts?
  • dang dw Aug 17, 2008
    Yeah, we have no lights, no power I guess. Breaker and GFIs seem ok. We did smell a burning smell about 2 days ago when the dw was running, but had no problem with that cycle and have run it once since I think. No problems with the cycle, but then today....nothing! Can't start a cycle because the lights won't come on.
  • garyever Sep 18, 2008
    Same problem and I've already checked the wire nut connection to the power supply line and its ok. I have 14.5 volts to the selection buttons panel and digital display panel, but neither will function.
    1. How can I tell if the problem is the door switch or the one of the boards?
    2. If its not the switch how do I tell which board is out.
    3. Is there a more likely solution than the ones I have suggested?
  • 248 Answers
Try checking connection to dishwasher behind access panel in front, bottom. TURN POWER OFF FIRST!!
Posted on Nov 13, 2007
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
The dishwasher will not turn on. I've already checked my breaker box, and nothing seems to be wrong there with the dishwasher. It worked a few days ago, but now all of a suddden seems to have died.
I would first take a look inside the junction box were the power cord connects to the dishwasher. The junction box is located at the bottom of the dishwasher and can be access by removed the toe plate.
I have seen were one of the wire nuts that connect the power cord will come loose or burn off.
If the power cord is connected ok then I would check the thermo fuse with a ohm meter to see if it's blown.
Aug 03, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher doesn't seem to be getting power. Breaker looks good
first check the power connection behind the toe-kick pane,then theres a fuse in the control panel to protect the electronics which can open and kill power to the unit
Aug 02, 2011 | Viking DFUD042P Built-in Dishwasher
No water. valve seems to work. switch seems to work. No power to switch or valve. is there something wrong with the controller?
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
Aug 02, 2011 | GE Nautilus 24" Built-in Dishwasher
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from
Nov 27, 2010 | GE Dishwashers
U1 symbol, draw wont empty.
in my experiance as a service tech dishwashing powder is supposted to b non foaming. try running dishwasher with no dishes or powder in it for a couple of washes. that will get rid of excess soap. unit has to much soap in it and the pump will not pump out soap suds. please reply 4 more help.
Apr 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Seems to have no power but plug has power
Hello- First find power box under unit. Unplug power, open cover and inspect connections. If there is a problem- loose or bad connection-  repair and see if it will run. Let me know if this info helps- have more if needed. Thanks -Ed
Oct 18, 2009 | Maytag MDB7130 Dishwasher
Whirlpool dishwasher adp4407 wont start
be sure the door is shutting properly the door switch may also be bad
Apr 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Not getting any power MDBH950AWB
shut off the power and then check your connector nuts to make sure one of the wires has not pulled out part way
Dec 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
350 people viewed this question
Top Dishwashers Experts
