i have a toshiba laptop using a netgear wpn 111. I am using an airlink ar430w wireless router but it gives me a message about "limited or no connectivity" because "the network did not assign a network address" It says the signal strength is "excellent" my wife's laptop in the bedroom is able to get on the wifi signal in the house, and the netgear adaspter is able to access the wifi at the library. What is the solution?
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Airlink AR430W Wireless Router
when looking at the status tab the IP address, Subnet mask, Default gatewa and DNS are all zero's....
(More)
when looking at the status tab the IP address, Subnet mask, Default gatewa and DNS are all zero's. Any help re this is greatly appreciated.
we had our router connected for a year for a lap top that was in the house, but ever since the...
(More)
we had our router connected for a year for a lap top that was in the house, but ever since the laptop was gone we disconnected it. the router gives a strong signal throughout the house but the internet does not work. when attempting to configure the router the router can not be identified. then i don't know how to get the network key for the router. what is a network key!!!? please help i want to get this router connected soon
I have been trying to connect an Airlink101 AR670W to the modem. As soon I establish the...
(More)
I have been trying to connect an Airlink101 AR670W to the modem. As soon I establish the communication, the modem turns disable and fail to work. I proceed to install the router config, and it continues to be unrecognized. I check on the Web for the modem drivers and have not found them. It has also unconfigure the cmd. When I enter the instruction "Ping ..." (or any one), the PC returns a message; "Ping is and unrecognized command..."
st purchased this router had problems right out of the box and called their tech line. Got the most...
(More)
st purchased this router had problems right out of the box and called their tech line. Got the most abrassive person from india or someplace over seas, after about 5 mins or so I just hung up the phone and will be taking back the unit to place of purchase. Unit seems very problemmatic right out of the box and I recommend looking into another brand with better support
Hi my problem is that the connection is lost on my router every few minutes it dosnt bother the cpu...
(More)
Hi my problem is that the connection is lost on my router every few minutes it dosnt bother the cpu because it acually gets a connention about a second later but when im on xbox live it kicks me out and i have to reconnect and restart thats why i have to fix this problem im a teen and i love my xbox lol
