SOURCE: 89 GMC Sierra problem
there is an ignition module located rite beside the distributor cap on the distributor base these are well known for getting weak and heating up thus causing your engine to stall.
SOURCE: 2002 GMC Sierra 1500 rear brakes
The first problem that I see is.....
You got screwed, the rear brake shoes and the parking brake shoes and the same thing. The parking brake uses your back brake pads to set the brake.
Sorry man
Hi joelalthomas, if they replaced your brakes and you never even made it home they had better warranty the work and as for the "it was a common problem on 2002-2004 trucks" well check for Chevy recalls as this is a safety issue that would have been corrected at no expense to the vehicle owner, do a little more research my friend and let me know what happens, I will check around a little as well in the meantime I would find a new garage.Do not pay any more as you said your brakes worked fine until they worked on it good luck to you As for your 4x4 did you look at the left side when you did the right side? and were they bled off properly? you can visually check to see if the calipers are functioning
SOURCE: engine blowing oil from oil filler cap
I had the same problem. I changed the pcv valve and checked the hose. It still did the same thing. Then I checked the metal tubing that the hose connects to and found it was full of hardened gunk. I sprayed PB Blaster into the tube let it soak for awhile. Then took an old choke cable, put it on a drill and ran it into the tube like a drain snake. It took a while of doing this over and over but eventually got it cleared out. Now, no more oil all over the engine and hood compartment.
SOURCE: LOW OIL PRESSURE ON 2007 GMC SIERRA 1500. CHANGED
have it tested using a manual gage if still low then main baring ore most likely bad that would mean a over hall if is really low and bearings bad should be making rattle noise when started up first few seconds
Testimonial: "thanks alot.truck is not making a rattling noise.we did check it with a manual gauge.it read about 10 at idol. press. gets better as you incr speed"
